Coilovers too low in the rear!
Old Apr 20, 2014 | 02:51 PM
LolMooses's Avatar
I Installed some Powertrix OEM style coilovers with the seperate shock and spring in the rear (just like BC Racing, Megans, etc)on my 2003 g35 sedan,but the spring perch is maxed out as high as it can go and the car is pretty much slammed! I need it to go higher as I'm scraping on speedbumps and don't want to ruin my exhaust or anything else underneath there. Anyone have any idea as to what I can do to get it higher?
Old Apr 20, 2014 | 04:11 PM
Frankieg35's Avatar
Did u adjust them correctly??
Old Apr 20, 2014 | 07:28 PM
LolMooses's Avatar
This is the first time I've ever touched coilovers so chances are I didn't. All I know is that the ride height adjustment is physically maxed out and the car is about 1 finger gap in the rear. The shock body can be adjusted but I don't see how it affects ride height.
Old Apr 20, 2014 | 08:33 PM
Lartytiejdke3's Avatar
i run powertrix. the shock body in the back wont adjust the ride height. its all through the spring and spring perch. you put the spring mount back in right?
Old Apr 20, 2014 | 08:51 PM
LolMooses's Avatar
Yeah, both the bottom and top rubber mounts. Are you able to get the rears even close to stock height? Is it because I have a sedan?
Old Apr 20, 2014 | 09:10 PM
well i lowered mine so im not stock height to begin with. i dont think you being a sedan should matter not sure. have you talked to charles about it? hes one of the reasons i chose powertrix
Old Apr 20, 2014 | 09:15 PM
LolMooses's Avatar
I did and he said that at max height it should sit a little lower than stock, but this is easily 3-4", so I either did something wrong or I'm really just SOL :/.
Old Apr 20, 2014 | 09:31 PM
post up a pic
Old Apr 20, 2014 | 09:36 PM
LolMooses's Avatar
Unfortunately I dont have any right now :/. I'm going to try reinstalling and adjusting them to max height with the springs out of the car as a last resort before I ask for a custom spring from Charles.
Old Apr 20, 2014 | 09:45 PM
Frankieg35's Avatar
Put just the springs in, adjust them to the height you want then measure from top strut mount to lower mount and adjust strut and install..
Old May 5, 2014 | 05:09 PM
aogram's Avatar
this may be a silly question, but are you sure you have the right part #s. Might have got a coupe set by accident? Just a thought.
Post some pics too for visual perspective (from under the car too if you can).
Muski_G
Dec 1, 2023 11:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
