Front Suspension Feels Loose.
Old Aug 4, 2014 | 06:30 PM
JHereth22's Avatar
Best way to make the front of the car feel nice and grounded? Feels wobbly at 110+.
Ideas? Maybe new Struts, Sways, Lowering Springs? Thanks
Old Aug 4, 2014 | 06:47 PM
ScraggleRock's Avatar
All of the above.
New shocks, higher spring rates, poly bushings, new ball joints, sway bars, control arms, proper alignment. They all work together.
Old Aug 4, 2014 | 06:53 PM
JHereth22's Avatar
Getting the Shocks.. Whats some good Springs too get? Also Bushings have been done. Guess Ball Joints too. Control arm? Why? Alignment done.
Old Aug 4, 2014 | 06:55 PM
JHereth22's Avatar
Also what can be done to improve traction?
Old Aug 4, 2014 | 06:56 PM
JHereth22's Avatar
I've got lowering Springs for the rear, and 255/35/18 tires. But no traction -,-
Old Aug 4, 2014 | 08:19 PM
What all have you modded (suspension-wise) so far?
Old Aug 4, 2014 | 10:19 PM
JHereth22's Avatar
Poly Mods for control arm, and poly mods for rear shocks
Old Aug 4, 2014 | 10:20 PM
JHereth22's Avatar
What else should i get
Old Aug 4, 2014 | 10:38 PM
Adjustable upper control arms up front (kinetix v2 or SPC), front lower ball joints (steering knuckle), rear adjustable control arms (SPC or Eibach) and toe bolts, shocks, sways and an eibach pro kit if you want a modest drop. Or try to find some stock sport springs if you want stock height.
If you drop it with the eibachs tho you're gonna want some 25mm spacers.
Then get a full alignment and shoot for about -1.4 camber in the rear and -.08 up front.
Old Aug 4, 2014 | 10:47 PM
JHereth22's Avatar
Shocks...The KYB's
Springs... Some 350Z Tein S
Driver and Passanger Lower Ball Joints... Check this link http://www.partsgeek.com/catalog/200...all_joint.html
Think Id go with the first.
Sways, I'm going with stock just new.
Old Aug 4, 2014 | 10:52 PM
Originally Posted by JHereth22
Shocks...The KYB's
What's the point? That's not gonna make a difference. You need a thicker sway bar, not just a new one.
Also, the adjustable arms are gonna make a huge difference because of the alignment numbers you'll be able to reach. Proper alignment makes all the difference in the world.
Old Aug 4, 2014 | 10:54 PM
I've wanted to try those mevotech ball joints, cuz they're the only ones I've seen with a zerk fitting on the bottom. Not sure why no one else does that (that I've seen).
JHereth22's Avatar
I'm talking about sway links.. Not sway bar. Those bars are kinda pricyyyy
Old Aug 4, 2014 | 10:57 PM
Ahh, yes. Try to find some used ones tho. They make a huge difference.
JHereth22's Avatar
And yes the MevoTech's is what im getting...
