Brakes popping
Old Aug 31, 2014 | 11:37 AM
willmkent's Avatar
Brakes popping
Hey guys so, I overhauled the rotors and pads last year in October, a few days after the front brakes started to popping like they grabbed and stuck on a certain part of the rotor as it turned, really weird... Anyway I could never actually diagnose what was happening and then it went away permanently... So last week I bought new rotors that were zinc plated and installed them and again 2 days go by no issues and then the front brakes start popping under load.... Has anyone ever had this issue? I also noticed a few things after doing some research, there were no shims at all on the pads when I first replaced them so I never even knew the car came with shims, so hence there are no shims now. Also, I am slight confused on the appropriate orientation and purpose of that small metal strip that is featured on one side of the pad, what exactly is this for and how is it suppose to be installed into the calipers, *proper orientation*.
Thanks guys, i inspected my work and it looks proper and even used proper torque spec on the bolts when reinstalling, any help would be greatly appreciated
I will attached pictures later today, I'll take some to show my setup
Old Aug 31, 2014 | 02:56 PM
Frankieg35's Avatar
Are the slide pins working properly??
Old Aug 31, 2014 | 03:23 PM
Urbanengineer's Avatar
This would be my response. Clean 'em up and grease em up!
Old Aug 31, 2014 | 04:49 PM
willmkent's Avatar
Yea the pins came in and out easily and I cleaned them off completely and regressed them all as I out them back in, however don't forget on the front calipers they are actually bolts and do not have a slider function, that's only on the tears and the tears do t have an issue at all. I am so lost guys other than missing shims everything seems right, I just don't really know what the metal tabs are for on the sides of the pads.
Also this problem occurred in the same succession when I did my brakes last year and it just went away, no explanation at all, it may go away again but who knows and id like to know what the heck is going on to make it do that
Old Aug 31, 2014 | 05:33 PM
Maybe you have something caught in the wheel well totally unrelated to that.
Follow your brake line... Just saying, mine was hanging off after a dealer service I had done.
Old Aug 31, 2014 | 05:39 PM
Frankieg35's Avatar
Maybe the piston?? Did u rebuild the seals??
Old Aug 31, 2014 | 11:30 PM
willmkent's Avatar
PO have not rebuilt the seals so that could be a major possibility
Old Sep 1, 2014 | 04:42 PM
willmkent's Avatar
OK GUYS, UPDATE. I took the car out for a nice spirited drive with lots of braking! this morning... no issue at all..
WTF... I'm glad but....WTF
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
G35xdriver04
Nov 7, 2015 08:31 PM
MThawkins86
Oct 24, 2015 02:07 AM
bigmike
Sep 17, 2015 01:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
