Suspension Advice
Old Apr 4, 2015 | 08:54 PM
Lawmen23's Avatar
Suspension Advice
Hi guys, I'm new to the forum. I'm just looking for some advice. I have a 2007 G35S Sedan with 150k miles on it. Engine runs great but the car rides very bumpy now and it's been going on for awhile. I'm not exactly sure what to replace so I thought I'd ask. I figure someone here might have already experienced the same thing and had some advice. Any info is good.
Thanks,
-Chris
Old Apr 5, 2015 | 12:28 AM
gary c's Avatar
Welcome to G35 Driver Chris!
Originally Posted by Lawmen23
Hi guys, I'm new to the forum. I'm just looking for some advice. I have a 2007 G35S Sedan with 150k miles on it. Engine runs great but the car rides very bumpy now and it's been going on for awhile. I'm not exactly sure what to replace so I thought I'd ask. I figure someone here might have already experienced the same thing and had some advice. Any info is good. Thanks, -Chris
With this kinda mileage Chris let's not assume anything. Find an independent brake/alignment shop in your neighborhood have them check out the suspension. Don't go near dealerships or ScraggleRock, they'll just throw unneeded parts at your ride and empty your wallet! Chances are all you need are shocks, KYBs will give you a factory ride and last as long as you own your G...they're not expensive. Good Luck again welcome to Driver, enjoy the ride!
Gary
Old Apr 5, 2015 | 12:47 AM
ScraggleRock's Avatar
Compression rods (with aftermarket polyurethane bushings), new polyurethane front lower control arms bushings, new shocks on all 4 corners, new adjustable front upper control arms (SPC, SPL, kinetix or eibach), new rear camber arms (SPC, SPL or eibach) and SPC eccentric toe bolts, new front steering knuckle ball joints. Wanna take it to the next level; get new adjustable end links (whiteline) and sway bars (eibach, Hotchkiss, motordyne)
Old Apr 5, 2015 | 02:59 PM
CanadianBird's Avatar
Why not a new G then?
Old Apr 5, 2015 | 04:01 PM
$600-1k (depending on deals you can find) and a day in the garage or buy a new car?
Not understanding your logic.
Old Apr 15, 2015 | 01:05 PM
neal.a.nelson's Avatar
Please keep us updated - I have the same car with 90K, but I need rotors and pads, too, so I don't wish to do the extensive parts list that was mentioned.
Old Apr 23, 2015 | 07:38 AM
G35fromPA's Avatar
To really restore it to like-new ride, I would do:
- new shocks
- new lower control arm and upper control arm bushings (Whiteline are best)
- new compression rod bushings (not so sure I would go poly on these)
- new ball joints
Might also consider replacing the springs as at 150K, they may be a bit less effective than they were earlier in their life. Probably not a necessity, but might just make things that much better.
Old Apr 23, 2015 | 09:38 AM
gary c's Avatar
You guys sound like the f'n dealership ^ just throw parts at it!
Even with a high mileage ride like Chris has it may need everything in the suspension replaced but I'd want an independent brake/alignment shop to sort it out. We don't know what's been done in the past, throwing parts at it doesn't seem like a great Bumpy ride Chris describes indicates the need for shocks, nothing else until it's been checked out by a trained suspension mechanic!
Gary
Old Apr 24, 2015 | 04:34 PM
G35fromPA's Avatar
Obviously, my assumption was that nothing substantial has been done to the suspension to date. At 150K, I'm guessing that is likely the case if the ride is that poor. Of course, have it inspected first. That should go without saying!
Old May 1, 2015 | 06:03 PM
Lawmen23's Avatar
Thanks for all the input. I haven't done anything with the suspension yet for the life of the car. I will have it inspected soon and let you know what they say.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
Learned Hand
Oct 1, 2015 09:02 AM
