help front end popping sound
Old Apr 14, 2015 | 07:17 PM
azenis88's Avatar
Exclamation help front end popping sound
So i have a 07 coupe and the front driver side pops when i come to a stop or turning the wheel right when in reverse at a slow roll pulling out. Not to much on a bump more when stopping. Ive check bolts with tire off and all tight theres no play in wheel im only guess is a bushing but not sure which one to pick from. took to dealer and they gave me deer in headlights look even after a test drive. I've look here for some old post but they are way before my model so any advise would help Thanks
Old Apr 14, 2015 | 10:05 PM
gary c's Avatar
Going to the stealership for anything other than warranty work isn't a great idea! My best advice to you is to find an "Independent Alignment/Brake" shop in your neighborhood, they deal with suspension issues 6 days a week. They'll put your G on the rack, within 15 minutes letting you know what is causing the popping/cracking noise your're experiencing...Gary
Old Apr 17, 2015 | 12:52 PM
UR2EZ's Avatar
guarantee its the lower control arm bushing, the inner one.
Amazon.com: Whiteline W52991 Control Arm: Automotive Amazon.com: Whiteline W52991 Control Arm: Automotive
Old Apr 23, 2015 | 01:08 PM
InfinitiGeeX's Avatar
Get a suspension and brake inspection on a lift.
Check
- Lower control arm and bushings
- Compression arms and bushings
- Knuckle ball joint
- Sway bar end links
Old Apr 23, 2015 | 05:03 PM
rtd730's Avatar
I may have a similar problem, I get a "cluck" noise at low speeds, parking lots etc. I've been doing the 'responsible' thing and just ignoring it for the past year, but it's gotten worse lately. If I jack up the passenger side with the wheels turned to the left, I can shake the tire and feel a little play and recreate the noise. Is this something similar?
Old Apr 23, 2015 | 05:15 PM
gary c's Avatar
That's wheel bearings ^ and should be taken care of before you lose a wheel! Any noises you experience from the front end can only be located by a mechanic while on a lift...Gary
Old Apr 23, 2015 | 05:35 PM
azenis88's Avatar
Almost the same but no wheel play at all
Old Apr 23, 2015 | 07:38 PM
Exactly what Gary said. I had the same issue which got worse as time went on. Definitely wheel bearings.
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
atk08
Jul 30, 2015 03:12 PM
newg37
Jul 26, 2015 09:32 AM
cyrus32
Jul 18, 2015 06:22 PM
