Front right wheel stick!! Bizarre!!
Old Jun 11, 2015 | 10:00 PM
brane123's Avatar
Hello everyone, i have a bizzare problem. I lift the front wheels and spin them with my hand ,driver side no problem but My front passenger wheel is difficult to turn when i tighten the wheel lugs.you need a lot of power with your hands to turn. It won't spin freely. Now here is where it gets weird.Once you loosen the lugs slightly it spins freely.Any clues to why this happens?
Old Jun 11, 2015 | 10:25 PM
herrschaft's Avatar
Probably a warped rotor. Are the pads worn evenly?
Old Jun 11, 2015 | 10:33 PM
brane123's Avatar
I changed the pads recently and the old ones where used evenly.Wouldn't you feel a pulsation on your foot if the rotor was warped?
Old Jun 11, 2015 | 10:39 PM
herrschaft's Avatar
^Yes. Might be a sticking caliper too.
Old Jun 13, 2016 | 10:54 AM
brane123's Avatar
UPDATE: Problem was the Brembo caliper, brake pads were not moving freely due to the corrosion.Took it out cleaned the corrosion replaced all screws and straightened metal plates on each side of the pads. Working great.
Thank you for all the help.
Xfactor
Dec 1, 2019 12:52 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
