compression rod bushings: replace unworn OEM?
Old Jun 12, 2015 | 05:31 PM
arficus's Avatar
My 07 coupe has less than 30k miles- there are no overt signs of worn compression rod bushings. I do drive the car near it's limits frequently, and have other suspension mods that help (Ohlins, fatter sways, chassis braces, etc). I already have some whiteline poly bushings- would I notice any improvement installing these, even though my OEM ones are not worn yet? Or should I just wait until OEM are actually worn?
Old Jun 12, 2015 | 05:38 PM
Urbanengineer's Avatar
Always go with white line if you drive it hard. Oem won't last. Ohlins on a car though??? Really?
You might* notice an "improvement" per say, but I'd wait.
Old Jun 12, 2015 | 06:00 PM
arficus's Avatar
Really. Can't say enough good things about them. Originally had Tokico D-spec and Eibach (both sportline and prokit), and the Ohlins took the car to a whole new level. Better handling at the extremes, yet more forgiving, more predictable all along the spectrum. Suddenly, my G had a certain poise and balance that made it more fun to drive even as a dd. Any regrets I may have had about not buying German again were gone. They're discontinued- get them while you can.
Old Jun 13, 2015 | 12:18 AM
ScraggleRock's Avatar
Steering feels about 100% better with polyurethane comp rod bushings. Feels very very tight and precise.
Old Jun 21, 2015 | 11:58 PM
leo38cheng's Avatar
any brand you recommend.
Old Jun 22, 2015 | 01:54 AM
I've only used energy. Lots of people swear by whiteline. Some don't like energy because of creaking, but adequate lubrication (with silicone lubricant) has yielded me results better than most. You really gotta have them swimming in lube.
Old Jun 22, 2015 | 01:09 PM
arficus's Avatar
Whiteline for dd seem to be the consensus, SPL for track, but be aware SPL will make you ineligible for certain SCCA categories (I think all the street categories don't allow for solid metal bushings, someone please chime in if I'm wrong).
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
