Help!!! Brake problem
Old Mar 4, 2018 | 08:57 AM
russ06's Avatar
I just bought an 06 G35 Coupe and when I get over 10 mpg the front abs activate. Once the brakes let go, the VDC and SLIP light come on and stay on until the car is shut off. The car had smaller tires on the front, so I initially thought that was the problem. So now I have the same size tires on all four corners. I also put on new brake pads all the way around too. I did notice that the front right caliper was harder to compress than any of the other calipers. The brake pads on the front right were worn way more than the front left. I am waiting for the caliper to come in and am hoping that this will be the fix. Any other ideas out there? TIA.
Old Mar 4, 2018 | 10:02 AM
LoSt180's Avatar
​​​​My car did the exact same thing when a mechanic damaged the "tone ring" on the front hub. ABS would go nuts within a block from my house then the lights would come on the rest of the drive.
The car does a self test when you first start driving, that's why you notice it as soon as you go above 10 mph.
Bellow is a pic of what my ring looked like, the mechanic got in there with a screw driver. Other causes would be a damaged/failing ABS sensor, or mismatched tires. Since you now have new tires, you should inspect the sensors.
Tone ring, front hub
Old Mar 4, 2018 | 12:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you didn't bleed the brakes then that's probably your issue. It's a nonstandard bleed order as well so check the FSM, also definitely sounds like you have a seized caliper.
Old Mar 4, 2018 | 03:32 PM
russ06's Avatar
I did forget to mention that I did change the clock spring when I got the car due to non of the steering wheel controls working.
Old Mar 4, 2018 | 03:38 PM
Urbanengineer's Avatar
Did you.... check what was posted..?
Old Mar 4, 2018 | 06:18 PM
cleric670's Avatar
BANNED!!!
Clock spring has absolutely nothing to do with the VDC /SLIP light I think, even if it was damaged and crossing wires for the cruise buttons it still wouldn't cause those lights I believe.
Old Mar 5, 2018 | 08:32 AM
LoSt180's Avatar
You need to make a trip to the dealer and have them do the steering angle program. There's a steering angle sensor as part of traction control system. It needs to be re-centered when you replace steering parts, normally a rack, but you just as easily could have put the steering wheel on a tooth off. ABS/Slip lights are all related to traction control system.
Old Mar 5, 2018 | 09:13 AM
FreshLikeAG's Avatar
Or buy nissan datascan 2. They'll charge more than the program itself. Literally takes 5 secs
Old Mar 5, 2018 | 12:09 PM
LoSt180's Avatar
Nice! I bought their android app, obviously limited compared to full desktop software.
Old Mar 5, 2018 | 02:09 PM
I've always wondered if there was a difference. I thought no way you can do all the same stuff through bluetooth. And with the price of the desktop software at $70 compared to the $5 app.
Old Mar 5, 2018 | 05:17 PM
russ06's Avatar
Ok, I changed the caliper and the ABS still activates when I go over 10MPH. I do not remember the ABS doing this before I changed the clock spring. It also seems like only the right front brake is activating. I haven't checked the sensors or the tone ring yet, I will be doing that within a few days.
Old Mar 5, 2018 | 05:33 PM
LoSt180's Avatar
Sounds like it's the steering angle sensor needing to be reprogrammed. It's only triggering one wheel because the car thinks you should be turning but the YAW sensor recognizes you're actually going strait.
Old Mar 8, 2018 | 08:27 PM
russ06's Avatar
I got the steering angle sensor reset and the abs self test works fine. But after driving for about a half mile I found out that the abs activates whenever I turn a corner, either to the left or the right. And it activates whether the VDC is on or off. Any ideas????
simaticoo
May 5, 2012 12:25 PM
FIFA RACING
Brakes-Vendor
19
May 7, 2010 04:49 PM
DriveLineSales
Brakes-Vendor
Jan 22, 2010 03:07 AM
RAVSPEC
Brakes-Vendor
Apr 3, 2007 04:14 PM
y.dan
Jun 22, 2006 07:50 PM
