06 G35 No Speedo
06 G35 No Speedo
Seems odd to post this here but as I have learned the speedometer is somehow tied into the ABS or or functioning off of the abs pump. So ,can someone please explain exactly how this works and what direction I should take to fix. Bought an ABS Pump to install but its just not clicking.
Thanks
Thanks
No, the speedometer needle moving is directly related to the wheel speed sensor data being sent to CAN and interpreted by the combination meter which controls the stepper motor for that needle. VDC also uses the CAN data for it's own calculations to determine wheel slip and actuate the ABS motor.
Sent it to the Stealership and was told they couldn't go any further due to the abs pump not working and needing another 5hrs to diagnose the problem. They did however give me the electrical print out
04g35mt
Audio/Video/Electronics
Jan 27, 2015 11:34 AM
