Confirmation of creak - compression rod or sway bar?
Old Sep 21, 2018 | 02:09 PM
Jhansenscu's Avatar
I suspect this to be my compression rod or sway bar? Can anyone confirm? This is my 07 G35 sedan sport. Happens in hot weather so it has been difficult to replicate when I’ve had time to bring it in to my mechanic. Any help is appreciated.
Old Sep 21, 2018 | 03:21 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I usually unbolt the strut from the top, the upper ball joint from the steering knuckle, then you can work everything independently. Helps to put a small floor jack under the compression arm at the steering knuckle to get the strut back up into place, use one hand to line up the holes and the second hand pumps the jack since it's like 50-60# worth of equipment.
LLumley
Apr 20, 2017 12:02 PM
ninjabong
May 4, 2016 05:17 PM
stockae92
Nov 11, 2014 11:47 AM
studio54
Dec 18, 2013 02:02 PM
