Inside of my rear tires are wearing out fast
Old Jan 6, 2019 | 02:13 PM
Geenice110's Avatar
Custom 2 tone coupe with deep dish wheels and red guts interior
I have a 03 G35 coupe and I recently changed my rear wheel width from a 10 to a 13 inch . Within 2 weeks I wore out one tire in the rear then 2 weeks later the other side tire wore out . What is the cause of this problem ? Wheel alignment , replace rear struts , camber fkit or springs ? Not sure what would fit this issue .
Old Jan 9, 2019 | 06:56 PM
Blue Dream's Avatar
I drove ttrank's car solo
I've moved this for you to the appropriate sub-forum. Your alignment is out of whack and the other things you mentioned are part of the alignment equation. You need to take the car to a good alignment place, not chains like Pep Boys, Goodyear, Firestone etc. and have an alignment done. If you're lowered at all you will likely need aftermarket camber and toe pieces for more adjustability but worn springs, shocks, bushings etc. can all affect your alignment
Old Jan 9, 2019 | 08:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Post your latest alignment results and we can tell you what is wrong.
Old Jan 9, 2019 | 09:19 PM
gary c's Avatar
Why did you put such a wide wheel on the backside of your coupe? Are you going to do a wide body kit? Tell me you're not one of those guys running that trendy over camber fad look? Camber kit and alignment will get you what you're looking for!
Gary
chrismtb
Mar 5, 2018 01:44 PM
NyCrAzY
Apr 21, 2017 02:47 PM
mc2
Mar 25, 2010 01:43 AM
TurK
Jan 18, 2010 11:27 AM
azeem
Apr 28, 2004 03:39 AM
