Off Center Click in Steering Wheel, Upper Column
Old Nov 29, 2019 | 11:09 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would also shoot the steering shaft u-joint from below the vehicle. It's possible it's slightly binding up and the vibration/noise is being sent up the shaft.
Especially since it's such a high failure rate item on higher mileage vehicles.
Old Jan 14, 2020 | 03:48 AM
Jakasd's Avatar
Hey, I've gotten this clicking feel and sound through my steering wheel for a couple months now, did you ever find out the problem? I'm thinking its might have to do something with the joints on the column but I haven't taken a close look at mine yet. I think theres an upper and lower U joint for our cars, not exactly sure.
Old Jan 14, 2020 | 09:28 AM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
It is contained in the joint on the column, right where it pivots and penetrates the firewall. I found if you reposition the steering wheel slightly, it would go away but return again after a few weeks.
I sold the car to my buddy (he will likely sell it back to me when he no longer needs it in a year or so). Right before I sold it to him I got under the dash, took off the lower dash knee panel for better access, and sprayed the snot out of the inside of the steering column boot at the firewall. I used the Liquid Wrench version of WD40 and a long spray straw. Was careful to not make a mess. I think this improved it.
Last edited by kelman81; Jan 14, 2020 at 10:27 AM. Reason: already posted reference pics above
Old Jan 14, 2020 | 10:00 PM
Jakasd's Avatar
Okay thanks! I will take a look at it when the weather gets warmer and see if my joints need replacing.
Old Jan 14, 2020 | 10:03 PM
kelman81's Avatar
I mean to say you can’t see the joint, it is hidden in the boot. Try changing the angle of your tilt and spray the joint thru the boot as a described above
R_Rod
Oct 6, 2019 08:29 AM
mryner4
Oct 8, 2013 09:39 PM
P.F.
Jul 9, 2013 10:59 PM
dynamik
Apr 25, 2013 11:23 PM
elrooko
Mar 25, 2005 09:39 AM
