Brakes loose
Old Dec 25, 2019 | 12:28 AM
NitroGoBrazy's Avatar
G35 sedan base
Brakes loose
So 4 days ago I got new brakes and rotors and the front right wheels brake line was broken an leaking and the guy said he will tighten it and the problem will be good to go. Well I drive off after pumping the brakes and everything and since that day my brakes now requires me to push down all the way to stop fully or push down all the way an than let off an push again an then the pedal becomes tight like normal pressure. Why is this? we plan on bleeding the lines an re adding fluid. But what do you guys think it could be? Brakes was fine before change. It’s a g35 sedan base 2006.
Old Dec 25, 2019 | 02:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Air in the lines.
Old Dec 25, 2019 | 02:14 PM
G35 sedan base
Air in the lines.
Okay I’ll let him know we got to bleed the lines! Thanks for the reply
Montzster
Aug 14, 2017 10:39 PM
JC-RH
Mar 17, 2007 06:33 PM
infini_
Feb 14, 2007 06:54 PM
fabulustt7
Aug 13, 2006 06:39 PM
