Coilover clanking issue
Old Jul 5, 2023 | 03:16 PM
miech's Avatar
Black, 6-speed,
So recently I got new swift springs for my g35 coupe. I didn’t like them very much so i took the strut out and put the old coilover springs back in.
After the install, my car is back to it’s normal spring rate, but every little small bump I hit, my coilover rattles and clanks, it does it on both sides on the rear. I’ve set my preload, do i need to set it higher? I’ve made sure to tighten everything very well when putting it back on, i feel like i’m missing something. Has anyone else had this issue before, it only had happened after i had disassembled it.thank you !
Old Jul 5, 2023 | 03:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
How much preload did you use? Very generic rule of thumb is start at zero, top lock nut snug tight with your bare hands, then set the lock nuts together, then tighten the top nut (spring) until you have about 1/4" gap which is typically the width of the spanner wrench (wrench fits between the two lock nuts).
Old Jul 5, 2023 | 03:47 PM
miech's Avatar
Black, 6-speed,
Yep, that’s what i did, i just set it to where my wrench was able to fit in between. I did it off of the car, does that make it any different?
Old Jul 7, 2023 | 11:02 AM
cleric670's Avatar
BANNED!!!
Not in this case no. I'd go over everything by hand, shake everything and see if something is obviously loose that might have been missed.
Old Jul 14, 2023 | 06:34 AM
VictorGarcia's Avatar
mustang 1965
It sounds like you might need to adjust your preload on the coilovers to resolve the clanking issue.
Spoiler
Old Jul 15, 2023 | 12:10 PM
cleric670's Avatar
BANNED!!!
I smell bots...
Kpxl1023
Oct 8, 2022 08:45 PM
SoCal04G35
May 28, 2020 12:14 AM
Tukeeg35
Accessories
May 31, 2015 07:46 PM
whoisthis
Dec 21, 2010 07:24 PM
Csquared
V36 Brakes, Suspension, Wheels & Tires
Mar 23, 2009 07:06 PM
