Why are you guys getting the hi performance brakes & tires?
Old Jun 26, 2005 | 08:40 PM
JimG35's Avatar
Tell me about the way you drive that make this stuff worthwhile. Tell me why the OEM stuff is inadeqate, for the way YOU DRIVE. "It looks cool" is not a valid reply.
Old Jun 26, 2005 | 10:14 PM
kenchan's Avatar
Cause I also have a modded Cooper-S which will out corner a G without
even trying. I needed to get the sus tuned to my liking without sacrificing
comfort... as a result, wider/sticker tires (S03's) were needed as part of
the package when I went with thicker swaybars and stiffer springs/dampers.
Old Jun 26, 2005 | 10:15 PM
G35fromPA's Avatar
The more apropos question is why is the OEM stuff inadequate for the way YOU DRIVE? Are you consistently overdriving your brakes to where you're fading your pads and/or boiling your fluid? If so, then consider some higher temp pads and beefier rotors, and flush the brake system with some higher boiling point brake fluid. Check out www.performancenissan.com, www.stoptech.com, etc. to find this stuff. If not, then the OEM stuff is plenty good.
Old Jun 26, 2005 | 10:16 PM
g35doc's Avatar
Tires will have to be inevitably replaced so you might as well go with something better/lighter.
Old Jun 26, 2005 | 10:18 PM
C-Keith's Avatar
If your investing all your money and time to making your car faster, it's probably smart to start thinking about brakes too...rumor has it though that it's cheaper to upgrade to aftermarket brakes pads and rotors than replace with new ones at the Infiniti dealership esp. with the Brembos. I believe someone told me the average brake life on our G is about 30K miles, depending on the driver.
Old Jun 26, 2005 | 10:58 PM
kenchan's Avatar
factory brembo's are fine for me on the street, thus have not chosen to
upgrade them.
Old Jun 27, 2005 | 01:23 AM
shodog's Avatar
For the same reason my Neighbor put a brama bull sticker on the door of his truck, because it looks cool.
Old Jun 27, 2005 | 09:06 AM
neffster's Avatar
DUDE, it just looks so darn cool!
Old Jun 27, 2005 | 09:45 AM
madchef's Avatar
Sounds like you don't push your car much, so I wouldn't worry about upgrading your tires or brakes.
Take your car to auto-x sometime and maybe you'll say to yourself "damn, wish I have a little more traction on that turn!" take your car to the track and you'll def want to upgrade your brakes (and fluid of course)
Old Jun 27, 2005 | 11:24 AM
G35_coupe_6MT's Avatar
I haven't, but I will upgrade to red brembo's. I miss the 04 ones and I dont even drive on the track, yet. I drive hard on the streets, and 04 brembos felt better than the 05 ones so even if I dont push it to the limit, its always good to feel how good the brembos are.
Old Jun 27, 2005 | 01:35 PM
jstwong's Avatar
For me, there was definately the looks part of it, but I'm also getting ready to be able to get my car out on a track. My neighbor is big into track racing [and he is an instructor as well for his racing club], so I think he is luring me over! lol...
Old Jun 28, 2005 | 08:56 AM
g35sedamn's Avatar
well i had 17" wheels on 215's stock. those would get squirly on the slightest turn under throttle. so i went with a set of the rays engineering 350z wheels. they are 18x8f and 18x8.5r. im using s techs for suspension. not much inmprovment in handling but it looks a good amount better.
Old Jun 28, 2005 | 10:32 AM
Balzz's Avatar
Brakepads and tires are the only things I can modify to stay in stock class.
Old Jun 28, 2005 | 10:34 AM
RaleighNC's Avatar
2pt. to be made:
1. I drive normally (whatever that may be) everyone knows the 5AT brakes on the 04 aren't worth a damn.
2. Because the standard brakes look so miniscule behind 20's.
I am turning my car into a show car and standard 04' AT brakes suck in the looks department. Upgrade to Wilwood's!
Old Jun 28, 2005 | 02:38 PM
Sukairain's Avatar
Because Brembo brakes work~
Now I need to look into SS brake lines and some new brake pads that won't turn my rims black after 2 mountain runs.
