Stoptech Stage 2 kit and HP+ front pads enough?
Old Oct 25, 2005 | 02:21 AM
mr_ecktid's Avatar
For a full day around a road course?
I'll be getting the kit that includes Stoptech slotted rotors, stainless braided lines, Motul racing fluid, and HPS pads in the rear and HP+ (I'll be buying these separately as HPS comes in the kit) pads for the front. I assume the front pads do the majority of the work and I'm wondering if I can save $100 by using the HPS pads in the rear? Thanks!
-Mark
Old Oct 25, 2005 | 02:32 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
you should have just posted this in the DFW forum...yes, that set will be perfect for the track day and YES, save your $100. Hawk HPS's are fine for rear...it's what I run...actually, I run HPS's all the way around and it stops my blown coupe. See you there.
Old Oct 25, 2005 | 06:48 AM
636Racer's Avatar
-Mark
If it will be your 1st time on a track day, you'll find out later on after inspecting your pads and rotors. just for piece of mind, flush your lines with new fluid to get the air bubbles out (if anyy - hence piece of mind.) after your track day. I hope your tires are good enough...if your on street tires, you wont be using your brakes at it highest potential. You normally start seeing that when your lap times start getting faster. most of all...have fun!!!!!
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
kinetek
Aug 3, 2015 04:25 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
bickfordbft
Jul 20, 2015 07:57 PM
