Z Car springs on Coupe..anyone know for sure ?
Old Oct 27, 2005 | 11:19 AM
Bigguy2000's Avatar
Looking for MINIMAL drop on new Coupe due soon. I am hearing conflicting story regarding use of 350Z springs on our Coupes .....question is, will they for sure drop the Coupes ride height the 1/2 " or so I've heard? My conflict is that the SPRING RATES of '04.5, '05 and ,06 Z Springs are SAME as our Coupes (MT's) ....... So if spring rates the same why would they drop the Coupe....S.horter Spring perhaps?
Anyone know for sure, I'd really appreciate the help. I've located some 350 Zsprings (I think) but no sense buying them if they won't lower my Coupe! Thanks for any assistance.
Old Oct 27, 2005 | 11:22 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Spring rate is not the same as ride height.
Old Oct 27, 2005 | 11:41 AM
Bigguy2000's Avatar
I understand that spring rate and rid height not the same
but my question is (was)... IF spring rates are the same and springs are interchangeable, how would 350Z springs lower my Coupe?
Hoping to hear from someone who has done this!
Old Oct 27, 2005 | 01:07 PM
PieroG35's Avatar
The Z spring is slightly shorter than the G spring. I'm not sure how much shorter it is.
Also, the weight of the G is greater, which means the spring will compress more on a relative basis. The spring rate number has units, lbs./in. I believe it is actually the spring constant and ppl call it a spring rate.
Higher load will result in a reduced spring height. This may account for the a fraction of the difference.
Piero
Old Oct 27, 2005 | 01:12 PM
InTgr8r's Avatar
They're 1/2" shorter in height (installed)
G35Maxedout's Avatar
FS: OEM 18" W-n-T
The Big Question IS:
Who has put STOCK Z-Springs on their G35 Coupe and what effect did it have? How much did it lower your car and did it ride better, worse or the same? What do I ask for when purchasing the correct springs? What year, what model (track, touring, etc etc)? Stock part number would be great...
I'm interested also.
Old Oct 27, 2005 | 02:02 PM
Bigguy2000's Avatar
Well if spring actually SHORTER that answers my question!
Piero
Piero....Damn, we're going to get to the <<bottom>> of this yet!! Heh,heh.
Just wanting to make sure before doing useless swap. Did not you say that a Bud of yours did this? Did you view results? Noticeable?
Note To others: I believe swaps to 04.5, 05 and 06 MT Coupes need Z springs from 04.5 Z's and up to match spring rates.
Old Oct 27, 2005 | 02:18 PM
g8tor20's Avatar
FGC's official flip flopper
I believe the spring rates for the G didn't match the 04.5+ Z's until the sport package came out in the G. So...all those with 19" OEM wheels have the higher spring rates and need the compareable 04.5-06 Z springs
Old Oct 27, 2005 | 02:34 PM
PieroG35's Avatar
Yes you are correct, those G's w/ the OEM 19's get the revised Z springs.
Old Oct 27, 2005 | 02:42 PM
PieroG35's Avatar
I have a good pic of an 04' G coupe on 03' OE Z Springs. I can't post the pic for some reason.
The drop is noticeable. The guy told me 0.75"F/ 0.3"R
PM your E-mail address to me and I'll send it over.
Old Oct 27, 2005 | 03:00 PM
Bigguy2000's Avatar
nissan parts guy sez
....."ALL Z Springs Alike".....(same part #)
G figure ????
PIERO....,.Hit me at coester@webtv.net
Old Oct 28, 2005 | 12:16 AM
Triple8Sol's Avatar
I have them, and they're fine. I'm also selling an extra set I have here: https://g35driver.com/forums/wheels-tires/67722-complete-350z-suspension-springs-shocks-struts.html
Old Oct 28, 2005 | 02:00 AM
g35cas's Avatar
I have an '03 coupe with '03 Z springs. 1/2 in. drop all the way round and alignment was within spec's. Subtle change in look and handling(lower center of gravity).
Old Oct 31, 2005 | 09:03 AM
TexasNissanDude's Avatar
Question
Originally Posted by Triple8Sol
I have them, and they're fine. I'm also selling an extra set I have here: https://g35driver.com/forums/showthread.php?t=67722
Your linky isn't working for me. Could you PM me with the specs of the sale for your Z springs. What year are they off of?
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
joel extreme
SOCAL Meetings & Events
Jul 27, 2015 11:59 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
joel extreme
Jul 23, 2015 04:13 AM
Scredeur4
Jul 17, 2015 06:30 AM
