More Suspension Advice - Please
Old Dec 31, 2005 | 02:29 AM
CMT1111's Avatar
Question More Suspension Advice - Please
Thanks for the advice, I've figured out that the 1st mod will be the hotchkis sway bays. Some were recommending D-Specs and coilovers. If I do that, How much can you lower without having alignment & tireware issues? Can I use the D-Specs with my "sport suspension" springs? I wold not mind .5" - .75" drop, but I'm really looking for more road feel.
Thanks
Old Dec 31, 2005 | 11:43 AM
kenchan's Avatar
you can use the D-Specs on your current stock springs.
the max drop you can do without getting an alignment is probably
1/2" even so, you'll be cutting it kinda close.
not sure if Hotchiks fixed their bars yet, but make sure you get the
collars on the bar before you install them. i recommend Stillens over
the hotichkis for that reason as the stillens come pre-welded with collars.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
Learned Hand
Oct 1, 2015 09:02 AM
