How difficult to install / adjust Tokico D-Spec shocks?
Jan 13, 2006 | 11:34 AM
I've got a 2005 G35 Coupe 6MT and the ride is too harsh around town for my wife - so I'm looking at getting the adjustable shocks. Hopefully, improves the ride quality a lot, and I can easily change them when needed for fun or racing.
How hard to install the Tokico D-spec adjustable shocks? Any installation guides online?
How difficult to adjust them once they're in?
Reply 0
Jan 13, 2006 | 05:44 PM
The install isn't too bad if you have a good jack and jackstands. There is a FAQ guide here: https://g35driver.com/forums/showthr...hlight=springs
I don't think I had to put the compressor on the springs to get them off, just used the compressor once the front shock assemblies were off the car.
The fronts are simple to adjust, just pop the hood, remove the little caps and adjust. The rears are a little tougher. If you jack up the rear (I jack on the rear diff) and put stands underneath, it takes about 20 minutes - no you don't have to take off the rear tires. Once jacked up, you take the two nuts out of the top of the fender that secure the rear shock body, compress the shock, and adjust the top just like the fronts. Thats about it! I adjust mine before/after each autox (monthly) b/c the roads are pretty rough out where I work. Good luck!
Oh yeah - here's the jack I use: http://www.sears.com/sr/javasr/produ...Lift+Equipment it was well worth the investment!
Reply 0
Jan 14, 2006 | 10:37 AM
the dampers might soften it up for you, but the harsh ride could be coming
from your stock springs and even your tire pressure.
the d-specs are easy to install if you've worked on cars before. it might
be challenging for a newb to do the front, but just take your time. it's
pretty much self explanatory.
if you want to do it right, i would recommend getting progressive rate
springs and d-specs. but not sure if you're wanting to drop the ride.
Reply 0
Jan 14, 2006 | 02:32 PM
No, the ride is low enough for me. ('05 6MT with sport package, 19" rims, etc). Just wanted to improve ride quality for road trips and to silence my wife
Reply 0
Jan 16, 2006 | 09:34 PM
Will D Specs give a smooth ride, I am lookign to dfrop my car a little over an inch and want to get something with the best ride? Would these be my best bet?
Reply 0
Jan 16, 2006 | 11:49 PM
Yes these will give you good ride quality. Mine are getting in on friday, can someone please tell me how to adjust the rear shocks from inside the car on the sedan with reclining rear seats. Someone must know an easy way, thanks!
Reply 0
Jan 17, 2006 | 02:38 AM
Quote: Yes these will give you good ride quality. Mine are getting in on friday, can someone please tell me how to adjust the rear shocks from inside the car on the sedan with reclining rear seats. Someone must know an easy way, thanks!
This thread was from the old board so the pictures are gone. But the instructions should be self explanatory.
https://g35driver.com/forums/g35-sedan-v35-2003-06/35882-pictures-how-adjust-rear-shocks-sedan.html
Reply 0
Jan 18, 2006 | 02:39 PM
We are currently sending a free set of rear shock extensions with every D Spec to the next 10 buyers, what this extension allows you to do is adjust the rear dampening without removing the rear shock everytime. You simply just adjust from the rear trunk.
Reply 0
Jan 19, 2006 | 01:57 PM
Quote: We are currently sending a free set of rear shock extensions with every D Spec to the next 10 buyers, what this extension allows you to do is adjust the rear dampening without removing the rear shock everytime. You simply just adjust from the rear trunk.
Sounds great. How much are these normally? Is it a Tokico item? How are they installed?
Reply 0
Jan 23, 2006 | 06:18 PM
I wouldn't say the install is easy... it's do-able but just a PITA for the fronts. The rears are SO easy! Getting the compressed assembly out was a bee-hotch!
Reply 0
Jan 23, 2006 | 07:14 PM
How much for these shocks?
Are shocks/springs better than a coilover system?
Reply 0
Jan 24, 2006 | 12:35 AM
D specs roughly cost around $600.
Can't intelligently answer the second question but I believe it depends on the purpose...
Reply 0
Jan 24, 2006 | 02:18 AM
Used as a daily driver with some auto-x involved from time to time.
Reply 0
Jan 24, 2006 | 12:59 PM
$520 shipped is easy to find.
Reply 0
Jan 24, 2006 | 06:47 PM
Quote: Sounds great. How much are these normally? Is it a Tokico item? How are they installed?
Yes its a tokico item, list price is 29 bucks, install is very straight forward, just screw it on top of the shock, where the adjustment **** is. I can have 4 sets of Dspecs here, that I can speical price at $510 shipped. If anyone is interested.
Reply 0
