GT spec bars
Old Jan 21, 2006 | 11:12 AM
KjbAlto's Avatar
GT spec bars
For those who installed them, how long did it take you to do it? They look like simple boltons to me but a shop just quoted me a 2 hour job. I said forget it and I'll do it myself. Is it as simple as it looks?
Old Jan 21, 2006 | 02:50 PM
Destro's Avatar
Pretty simple, the rear was a piece of cake. the fronts weren't too bad. Much easier if you have a lift and helping hands.
Old Jan 21, 2006 | 04:32 PM
CarFanatic56's Avatar
^ any pics of them installed on your G?
Old Jan 21, 2006 | 06:05 PM
Silverbolt's Avatar
Theres a thread here with alot of good pictures of them installed. Try searching for it. I think the guy had a BS G on a lift. I orded mine last week, and should be getting mine soon. If I find a lift to use, to install them along with my sways that I should be getting Monday, I'll take pictures.
Old Jan 22, 2006 | 07:49 PM
Destro's Avatar
I did not take any pics of mine installed, but I will try to get some next time it's on a lift.
Old Jan 23, 2006 | 06:43 PM
thepanic's Avatar
here some pics of mine~~~
i had three of them... include a rear lateral bar which is not recommeded by gt spec... but i installed them cause i saw a enough clearence between exhaust pipe and gt spec bar...
result... during the first week, exhaust pipe was sitting on the bar but after pulled up the exhaust pipe a liitle bit, i could get more room between bar and pipe...
however, i took the rear lateral bar off cause of a bad rattle noise from rear...
i think it comes from TEIN CS coilover i installed with gt spec bars... i will see why the rattle sound comes out... now but i don't have a rear lateral bar with her...
if u want three of them... i think u better pull up the exhaust pipe, so u can get some more room to prevent a rubbing...
this pic was taken before adjust the exhaust pipe...
front bar is installed above the cover...
Old Jan 29, 2006 | 01:07 AM
Silverbolt's Avatar
I'm going to have mine installed tomorrow. Thepanic, did you try fitting the 4 point mid chasis brace? Any news of whether or not you got the lower lateral to work? Does the front tie bar get in the way when you're draining your oil?
Old Jan 29, 2006 | 09:04 AM
Destro's Avatar
The front tie bar is really not in the way when changing the oil.
It is slightly offset from the drain plug and should not get in the way.
Old Jan 29, 2006 | 03:57 PM
GReddySetGO's Avatar
Can you still use the splash guard in the front?
Old Jan 29, 2006 | 09:11 PM
Triple8Sol's Avatar
Here's a couple pics of my install:
More pics here: http://www.cardomain.com/ride/2046951/4
Old Jan 29, 2006 | 11:09 PM
Destro's Avatar
Yes, the splash cover fits right over the tie bar.
Old Jan 30, 2006 | 12:12 AM
Silverbolt-how do you like them?...noticeable difference in handling performance/ cornering/ steering?....make ride stiffer?.....does the rear tie bar rub agains the exhaust?
Old Jan 30, 2006 | 01:04 AM
Silverbolt's Avatar
I decided not to install them. I found out that one of my friends is custom making some, and hes going to make a set for me too. I held them up, and they look like they fit perfectly. The lateral bar sits a centimeter... or less... above the lateral bar too (those were his).
I'm selling mine if anyone wants them
Old Jan 30, 2006 | 03:45 PM
^ How much? I'm local
Old Feb 1, 2006 | 05:10 PM
SixFive's Avatar
So does this help the rigidity of the car and can anyone comment on the 4 point brace being usable on the sedan?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
