Replacement Shocks
Old Jan 26, 2006 | 09:31 PM
redz06's Avatar
Replacement Shocks
I have a 2003 G35 sedan with 33k on it. I have recently noticed that the OEM shocks are starting to go bad. So far, I can only tell when I go over a really big rise at speed, like the crown in the middle of a road crossing at about 60 mph. Have any of the forum members replaced shocks and if so, what make/model did you go with? Did you R/R them yourself or pay a shop to replace them for you?
Old Jan 26, 2006 | 10:27 PM
absolutg's Avatar
workin...
can't u warranty this problem???
Old Jan 27, 2006 | 02:29 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If your just replacing the shocks i'd go with Tokico D-Spec shocks.
-GP-
Old Jan 27, 2006 | 09:35 AM
Q45tech's Avatar
Think you'll find shocks are a wear item and until they leak they are not covered. Even though by 33k they can be considerably worn and low in rebound stiffness. Most last for 60k with oem springs.
Old Jan 27, 2006 | 10:20 AM
liukai's Avatar
do you guys know with the Dspec shocks, if using 350z stock springs, would give you more of a drop than the h-tech 350z springs for a sedan?
Old Jan 27, 2006 | 11:44 AM
blackonblackG's Avatar
well lets see... If the H-tech lowers a Z then it would lower a sedan more then the stock Z springs.
Old Jan 27, 2006 | 12:34 PM
Endless G's Avatar
i will want to know who has 350 h-tech /w D-spec
Can someone give some input!??!?
Old Jan 27, 2006 | 03:19 PM
liukai's Avatar
yea, i kinda kicked myself in the butt after i realized what i wrote
Old Jan 27, 2006 | 03:35 PM
godmans's Avatar
maybe in the nuts =)
snic09
Nov 8, 2017 01:46 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
smartin0924
Aug 13, 2015 07:29 PM
si_driver
Aug 11, 2015 07:08 AM
cyrus32
Jul 18, 2015 06:22 PM
