Tein springs on coupe
Old Feb 6, 2006 | 12:00 PM
spirogyro's Avatar
I see alot of people have these, but is it true that it will drop the car about an inch? Why are they soo cheap? I think I've seen them for like $150. Is the drop noticable, and if I get them, where do i install these?
Old Feb 6, 2006 | 01:01 PM
nnkfws333's Avatar
They are cheap because these are just the springs. Normally when you swap out for lower springs your stock struts will have a shorter life span because they were not made for those springs. Your supposed to get some better struts/shocks that are made for those springs and the price will go up.
Coilovers are more expensive due to adjustability (height and dampening). They also can take more abuse since they were made for either racing or normal driving. They let you further tap into your suspension.
Any shop can do it for you, I do the work bymyself, its not hard at all.
Oh yeah dont forget you might need some sort of camber plates or bolts to adjust your camber (depending on your drop) and get an alignment!
Old Feb 6, 2006 | 01:06 PM
2Evolved's Avatar
go with a coil over kit.. its way better.
Old Feb 6, 2006 | 01:48 PM
CHIZELD's Avatar
Love Poker!!!
If you had to get the springs, would you get Tein S-techs or Tanabe? Thanks in advance....
Old Feb 6, 2006 | 01:55 PM
e420x's Avatar
Mod Junky!
I just bought a set of 350z Tein H-Techs which are getting great reviews
Old Feb 6, 2006 | 03:29 PM
GReddySetGO's Avatar
I got S. Techs for my G. I like them. Can't beat them for the price too. Yes, the drop is noticable.
Old Feb 6, 2006 | 03:32 PM
e420x's Avatar
Mod Junky!
The 350z H Techs have a bigger drop right?
Old Feb 6, 2006 | 04:44 PM
Cactus's Avatar
No, S's are more drop.
Old Feb 6, 2006 | 04:46 PM
Chucky's Avatar
There are S-tech's for the Z and the G. The G type has more of a drop and a softer ride than the Z type.
Old Feb 6, 2006 | 06:36 PM
Cactus's Avatar
I think it is the other way around. Take another .5 inches off with the Z type. I'm not completely sure so don't take my word as the final answer!
Old Feb 6, 2006 | 07:17 PM
mrjonang's Avatar
i just put up some tein s-techs a few weeks ago. they roughly drop around 1" all around. like .9" in the front and 1.1" in the rear. looks sexy!
Old Feb 6, 2006 | 07:38 PM
MaxGsII's Avatar
...Tein Flex Type Coliovers! You pay a little more, but they are well worth the costs!
Old Feb 6, 2006 | 09:27 PM
blazinZ's Avatar
hotchkis w/ good spring rates as well about .9-1.1 all around
Old Feb 6, 2006 | 09:32 PM
Jee_35's Avatar
I was thinking of going Tein H-Tech Springs with the Tokiko Shocks. Will this be alright with the strut issue? Someone said that I should even go with sway bars, to help with it. Basically, the stock struts/shocks are for the stock springs so if you replace the springs, you're hurting the struts/shocks. So if I were to go Tokiko shocks and H-Techs will this be ok?
Old Feb 6, 2006 | 11:34 PM
EricIsKlumzyee's Avatar
