Camber arm install problem
Old Feb 15, 2006 | 11:59 PM
waijai's Avatar
i.love.gold
Friend of mine installed some camber arms tonight, and the camber was actually WORSE than before install. It also made his toe point in really bad. Is this normal? Does it need to be adjusted by an alignment shop after install or can he just eyeball everything?
When elongating the arms, does that induce more negative camber or more positive camber?
Old Feb 16, 2006 | 12:01 AM
meatbag's Avatar
You need to take it to a shop and have it aligned
Old Feb 16, 2006 | 12:42 AM
kenchan's Avatar
there is no way in hell you can eyeball the camber and toe on this car and think it would run correctly. it is a very complex system and MUST be
computer aligned.
Old Feb 16, 2006 | 07:27 AM
Chucky's Avatar
When you elongate the arm it creates more negative camber. Get it computer aligned.
Old Feb 16, 2006 | 10:28 AM
kenchan's Avatar
and screws up your toe as well. this is why this car's hard to align.
Old Feb 16, 2006 | 03:19 PM
waijai's Avatar
i.love.gold
Do you think there is anyway the camber arms are to blame? or does it just need to be worked on my an alignment tech?
Old Feb 16, 2006 | 03:32 PM
silvernole12's Avatar
We installed mine this weekend and what we did was set the length to the current length of the stock arm. Then let the alignment tech get it to where it needs to be.
Old Feb 16, 2006 | 04:46 PM
kenchan's Avatar
moog- probably just needs adjusting on an alignment rack.
my aligment was f- too when i installed my Stillen rods...then just took her
in and got an alignment.
Old Feb 16, 2006 | 07:15 PM
SLVRG35's Avatar
I couldnt agree more, it HAS to be done by a shop. I recently did springs, struts, camber/tractions arms and started with the arms at the same length as the oem ones, but then decided to adjust it a little myself since I was to be traveling from Oklahoma to Missouri before getting it aligned, so that the springs could settle. Bad idea, I totally ruined the (2) 275/35/19 Toyo T1R's I had. I'll show some pics after I get my car back home.
Old Feb 16, 2006 | 11:37 PM
waijai's Avatar
i.love.gold
update....friend took it to an alignment shop, they installed the arms and aligned it...works fine.
jsimonk
Dec 22, 2023 03:49 PM
Fireman07603
Aug 9, 2015 06:00 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
