2005 G35X Brake
2005 G35X Brake
Per my local Infiniti dealer, brake are not covered as before. 03-04 36,000 miles.
They told it's not covered anymore. Mine is squeeking like crazy again with only 15000 miles.
Originally Posted by Neal376
the 06x has the larger breaks.... something was obviously wroung with the 05x breaks.
My sales consultant is trying to find a way for me to get a pair of 06 breaks
Unless Nissan offers a very sweet upgrade deal to the larger brakes (don't count on it) I will be going to an aftermarket big brake kit when my brakes wear out.
FYI...the brakes on my 05X are the same ones on my 03 Altima, and that car had no brake problems in 55,000 miles.
I had a 06x loaner recentely. The breaks filled the entire space withen the rim. The pedal felt like a brick, Big Difference!!! Car stopped much more smoothly and much more confident!
mine were squealing bad a 9k miles... had pads replaced and rotors shaved...
service manager showed me the pads and what the problem (atleast on mine) was... He first said that the 03/4's pads were mad of a soft compound. The 05's got a harder compound created with more metal. In mine, there was a pice of metal in the pad that would not wear down and scraped into the rotor making it squeal like a b!tch. Replaced under warranty at infiniti of massapequa.
no not at all. As a matter of fact, they didnt even second guess me. My consultant is Kenny. You should talk to him. Atlantic Infiniti would of stared at me "like I had two heads". Dont even bother going to Atlantic. Even through the phone, Massapequa helped me with my car. Once my M's battery died, and I neeed a little help jumping it. Atlantic put me on hold and after 10 minutes I just hung up. Massapequa handed there line to a mechanic right away who immediatly said (after the car started) "if you have a battery problem, you should bring your car over here and we will help you out". I still dont know why Atlantic Infiniti is still in buisness.
yeah when i had brake issues, kings infiniti had the biggest douches working there, i called about 4 dealers and right away after speaking with the service manager frank i was confident that i found a great dealer in them
