Brake Caliper Paint Removal
Old Feb 24, 2006 | 06:23 PM
Derek S's Avatar
How Do I Get This Ugly Caliper Paint Offfff!!!!!!
Old Feb 24, 2006 | 06:24 PM
Raznips's Avatar
do you have brembo's?
Old Feb 24, 2006 | 06:32 PM
Derek S's Avatar
Originally Posted by Raznips
do you have brembo's? If so... why? Obviously you dont appreciate them lol.
not brembos, stock 04 calipers, i painted them RED and now i hate it, i want it offfff.
Old Feb 24, 2006 | 07:01 PM
firefox's Avatar
If the paint hasn't cured, just try using plain brake cleaner from any auto parts store.
If that doesn't work, use http://www.caswellplating.com/vht/stripfast.php. Strips it pretty fast, but I would take the calipers off the car (this stuff can take off powder coating). You don't want to acidentally spray this stuff on your car. Be sure to wear a mask, gloves, and eye protection.
Old Feb 24, 2006 | 07:38 PM
TheKnite's Avatar
Just clean it and paint over, like black or silver. Or gold if you want to be a brembo wannabe.
Old Feb 24, 2006 | 07:56 PM
vrsc's Avatar
^^^+1 1 or two coats would work
Old Feb 24, 2006 | 07:59 PM
truplay8's Avatar
THE BATMOBILE
dude your cooked
Old Feb 24, 2006 | 08:03 PM
firefox's Avatar
That's a good idea. I just saw a picture of slikster818's car. I like the black Axis Milanos. A painted silver caliper would give a good bit of contrast behind the wheels, yet not make it stick out too much.
You may want to try the G2 stuff to get a smoother finish. Or sand it down a bit and and use some high temp caliper paint.
Old Feb 25, 2006 | 01:24 AM
Derek S's Avatar
will this damage the brakes in ANY way?
Old Feb 25, 2006 | 03:38 AM
firefox's Avatar
I've done it twice to my Wilwoods (they came black). First time, I went with yellow, didn't like it. Then I went with candy red, and it got old after a year. Finally, went with a plain red that everybody has. It has to be just the right red. Too light, it looks funny; too dark, you can't see it.
For the yellow, I just used brake cleaner since the paint didn't fully cure yet. The second time, I had to use the stripper since the paint was basically baked on. Just to be safe, you can cover the piston with some piece of plastic (small piece of garbage bag) and tape around the piston. It's probably covered with brake dust so it probably needs a good cleaning anyway. Personally, I would remove the caliper completely to get into all the nooks and crannies. Just give it a good wash after you're done.
If you are still uncomfortable using this stuff, just take the other recommendation of painting it over with silver or black. In the end it will probably turn out about the same.
jsimonk
Dec 22, 2023 03:49 PM
kinetek
Aug 3, 2015 04:25 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
mushu
Jul 15, 2015 03:55 PM
