Lowering G35?
Old Mar 15, 2006 | 06:48 PM
  #31
luongdmd's Avatar
will i have camber issues, or tire wear problems with the tien basics????
Old Mar 16, 2006 | 10:56 AM
  #32
pdjafari's Avatar
most of the suspension know it all's run 350z h techs w/ tokico d spec shocks....
Old Mar 16, 2006 | 10:57 AM
  #33
pdjafari's Avatar
i believe kenchan runs 350z h techs front and eibach pro kit rear....but i could be wrong. i believe he does run aftermarket shocks (d specs or koni yellows..)
Old Mar 17, 2006 | 11:32 AM
  #34
seinsmeld's Avatar
Don't lower with just springs, see my post with the problems I am having.
Old Apr 2, 2011 | 04:47 PM
  #35
G35xAngel's Avatar
my suspension is stock on my g35x. i want a 1-1.5 inch drop yet i want the same comfort as i have now. i want it for looks and less body roll. and i dont want to pay a shvt ton worth of money on it. what should i do??
Old Apr 2, 2011 | 06:52 PM
  #36
4D05G35's Avatar
Talk about an old post revival. A little over 5 years old.
Try here
https://g35driver.com/forums/g35-sed...uspension.html
Here
https://g35driver.com/forums/g35-sed...on-thread.html
here
https://g35driver.com/forums/g35-sed...edan-faqs.html
It's all been covered a million times since this post.
Old May 28, 2012 | 03:02 AM
  #37
ILuvMyG35's Avatar
LOL, 5 years revival. But good for me. I am thinking lowering my 2004 coupe about 1". If I go with Tein Basic, do I need to get camper kit for both front and rear? and Toe bolts?
Old May 28, 2012 | 06:54 AM
  #38
Texasscout's Avatar
If all you go is 1", you really don't need to, but you will still get some tire wear on the inside. If you want it perfect, yes.
BTW, I think the Teins will give you 1.5", not 1".
Old May 28, 2012 | 09:19 AM
  #39
_LiL_G_'s Avatar
There has been mixed reviews some people say if you drop just 1" or less that they dont need a camber kit but to be on the safe side you should just get both the front and rear kit and call it a day
Old May 28, 2012 | 10:35 AM
  #40
TNC 718's Avatar
I dropped my '05 coupe on the Tanabe NF210 (1" front, .7" rear), and after two years, I ended up having to get camber kits for the front and back. Rear tires wore out really bad on the insides. I'm thinking about just going with coilovers in the near future. So Tein basics is the way to go?
Old May 29, 2012 | 05:30 AM
  #41
ILuvMyG35's Avatar
Isn't coilover is adjustable?? I think the front drops range is .7" - 2.6"?
How's ride comfort quality from the NF210 compare to the OEM springs?
Old May 29, 2012 | 07:00 AM
  #42
tasi's Avatar
I just installed NF210 and its much worse than normal, too soft. Im going back to orginal setup.
2006 sedan
Old May 29, 2012 | 09:14 AM
  #43
TNC 718's Avatar
I had my springs installed not too long after I got the car, so I don't remember how the ride was with OEM. The Tanabes ride pretty good to me, though. Not too stiff, not too soft (pause). The handling is better than stock of course, and is even better with the strut tower brace, sway bars, and camber kits. I'd recommend them if you want a moderate drop without going too low and having a crappy ride.
Old May 30, 2012 | 07:51 PM
  #44
ILuvMyG35's Avatar
I want to lower my car ~1" without having to sacrifing too much of the ride quality. The OEM is not bad at all except when turning at 40km/h or over. The car seems to be floaty in hard cornering.
Would you able to provide me with link to your setup? to the tower brace, sway and camber kit (front/rear?).
I am on a budget. So I am thinking swapping springs only and keep the OEM struts.
With OEM strut, which gives the best result? (minimal decrease in ride quality and better cornering)
Tein S-Tech for G?
Tein H-Tech for Z?
Tanabe NF210?
I don't wanna bottle out my struts, which is the best bet?
Old May 30, 2012 | 08:09 PM
  #45
TNC 718's Avatar
Tanabe NF210
GT Spec front strut tower brace
Hotchkis sway bars
SPC front and rear camber kits
