w/ the 03 STOCK CALIPERS (non-brembo).will.?
Will a larger than those regular rotors be possible? Like 14'' or anything? Or does it have to be proportionate to the caliper size?
I don't think you want to do that with your breaks. If you search for brakes you should find a few options. I know that bbk are about $2k to $2.5k for either front or rear. If you put big rotors you will need to upgrade your calipers and pads. I think there are some options at performancenissan.com.
Don't go cheep on your brakes!!!!
best to just leave it alone or just change out the pads
Yes, their is a big brake kit that relocates your stock calipers. They have a front kit and rear kit. This is the only one I know of that does this. The rotors are bigger at 13" in diameter but the thickness of the rotor is the same as stock.
http://www.racingbrake.com/OE_calipe...kit_s/2872.htm
Increasing diameter without increasing thickness is a half ***** solution.
Rotor mass and rotor temperature are directly related.......10% more mass = 10% lower temperature............a proper rotor would be 28-32mm thick.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
