Lifting car for sway install
Old Mar 23, 2006 | 10:41 AM
hootie981's Avatar
Hey y'all...
I'm installing my Stillen Sways this weekend at a friend's house. He has a drive-up hydraulic lift that will lift my car on all 4 wheels. Is it possible to do the installation this way, or do I need to use my jackstands and lift the car on the frame instead of on the wheels? I found an install guide on my350z, and it said to use jackstands--just wondering if it is possible using the other type of lift. Thanks for your help!
Old Mar 23, 2006 | 02:48 PM
richie's Avatar
a hydraulic lift at his house... whoa.. thats nice.
anyway you could get under the car and to the sways would do fine.... hydraulic lift sounds a lot better than using the jackstands.... the install guide on my350z assumes that most home owners do not have a lift at home =)
Old Mar 23, 2006 | 08:45 PM
ATL_Red_G35's Avatar
I think that for the front, you have to let the wheel drop. I've yet to do my front simply because I used the same thing your friend had last time. To hard to access it.
Old Mar 24, 2006 | 12:49 AM
kenchan's Avatar
i just used ramps.
Old Mar 24, 2006 | 12:54 AM
hootie981's Avatar
thanks for the replies. I will be taking my jack stands with me, just in case...
Old Mar 24, 2006 | 02:27 AM
richie's Avatar
mmmm, oh yea, when we did my sways, we lifted up the front, then slid the ramps underneath the two front tires...... we just did that, but I didnt know the wheels drop.
Old Mar 24, 2006 | 04:45 PM
myst's Avatar
Oo
I think it's so much easier to do it using a lift. I did mines on a lift and I can imagine how much more effort it would take to crawl under the car to do the work.
Old Mar 25, 2006 | 11:51 AM
g35guy86's Avatar
yeah i attempted mine with just jack stands but the angle made it way to hard to loosen the bolts so i had to go to a mechanic. about $60 for the install.
Old Mar 25, 2006 | 02:33 PM
Andy2434's Avatar
Originally Posted by myst
Oo
Yeah, with a lift, if you are fortunate enough to get the use of one, it is soooo much easier. With a second pair of hands, I had my HKS exhaust and Stillen bars installed in just a bit over an hour. Air impact tools are a must, as well.
Old Mar 26, 2006 | 08:42 PM
FenixL1P's Avatar
i just used ramp for both front and rear... front was pita because of the lower engine bay cover, but i didn't have to lower anything else like the exhaust piping supports when doing the rear...
to me it was so much easier doing the sway bar upgrade with the sways in a rested position, like when the car is driven onto ramps, than when the wheels are hanging down or suspended in the air....
Old Mar 27, 2006 | 08:41 PM
cyphr's Avatar
You can do the install fine using a lift just make sure you preload the suspension before torquing the bolts to spec (i preloaded my suspension by driving it on ramps)
Old Mar 28, 2006 | 09:06 PM
hootie981's Avatar
Thanks for all the replies guys...A friend and I installed my sways on Saturday. The hydraulic lift made it so easy. I didn't even have to unbolt the exhaust hangers to get the rear sway out. It's pretty cool being able to stand under your own car and see all that engineering under there! I'd definitely recommend a hydraulic lift to anybody needed to put their sways on.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
Frostbite91
Jul 27, 2015 05:25 AM
Ashton35
Jul 22, 2015 09:19 PM
vstypicals
Jul 20, 2015 10:55 PM
