Strange noise when turning - HELP!
Old Apr 3, 2006 | 02:19 PM
UFGatorG35's Avatar
Exclamation Strange noise when turning - HELP!
Every now and then (not constant, and happens more when cooler outside) I get a strange rubbing/grinding/clicking noise from the front passenger wheel when taking a hard LEFT turn (weight baring on that wheel in the turn). If anyone has ever been in a FWD car with bad CV joints, it sounds very similar to that.
The dealer "couldn't replicate the sound" (f'kn shocker there, eh?) and said everything looked good when they lifted the car and inspected it. Anyone have any ideas? I'm hitting a road course in a couple months and want to make sure I get this corrected if it needs to be! Thanks!
Old Apr 4, 2006 | 01:44 PM
UFGatorG35's Avatar
bump... anyone? nobody has heard of this?
Old Apr 4, 2006 | 01:50 PM
mistermojorizin's Avatar
if its a clicking sound you're hearing out of the window, it might be the rear axle clicking. ther's a tsb about this.
Old Apr 4, 2006 | 02:42 PM
UFGatorG35's Avatar
^^^ Thanks, but this is very different from that. I have also had a little of the clicking noise from the rear axle - this is def coming from the front.
Old Apr 4, 2006 | 03:40 PM
05Scoobyroo's Avatar
I hear the same thing in my coupe, and its def not the rear axle.
Old Jul 1, 2006 | 10:46 AM
vengeqi's Avatar
I've recently been hearing this too in my 03 sedan. can't figure out what it is and it doesn't seem to happen with every hard left turn.
Old Jul 1, 2006 | 11:41 AM
RBull's Avatar
Rated M
I've heard it twice now myself at very low speed left hand turn. Almost seemed like loose lug nuts or wheel bearing loose. Strange since it was only the two times and I've driven 1000's of kms since.
Old Jul 11, 2006 | 06:50 PM
dTor's Avatar
I also get this, and I can feel it in the steering wheel as well. It is very hard to tell when going straight, but when I'm making swooping RIGHT turns (like an interstate on/off ramp) I gets very pronounced. I am almost certain it is coming from the front, and it does not happen when I turn left.
Any ideas?
Old Jul 12, 2006 | 10:29 PM
Petoria's Avatar
same here.....dealer checked it out and said everything was fine
i asked my uncle who works with cars and he said that there might have been some water in the brakes or something
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
magnetism80
Feb 1, 2019 10:00 AM
G35-R
Nov 7, 2015 01:21 PM
mattdg35
Sep 14, 2015 11:28 AM
pasjr1972
Sep 1, 2015 10:17 PM
