Replace that brake fluid...
Old Apr 10, 2006 | 02:26 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Smile Replace that brake fluid...
:Getting on Soap Box:
Part of my spring ritual is to replace the brake fluid.... (just did it this weekend)
I was just wondering how many realize that this needs to be done periodically...
Moisture & air are the problem.
There are many ways for moisture to enter your brake system.
Condensation from regular use and humidity are the most common, with little hope of prevention.
Glycol based DOT 3 & 4 fluids are hygroscopic; they absorb brake system moisture, and over time the boiling point is gradually reduced.
It's really an easy job to do & yields immediate bennefit.
Pedal pressure really firms up & the brakes are much easier to modulate.
Stopping is definitely improved.
If you want to read a little more.... Stoptech has some great whitepapers
Old Apr 10, 2006 | 07:58 PM
bigwilly's Avatar
Ian,
How much brake fluid is required to replace / bleed the brakes on the sedan? I still have two bottles of Motul RBF 600 left I think they are 500ml. Do you want to do my brakes
Old Apr 10, 2006 | 09:03 PM
InTgr8r's Avatar
2 bottles is right, you'd actually have a little left over.
(note: left overs get tossed once the seal is broken)
I usually do mine when I switch over the snows to summers,
since it's up on stands anyway...
I use to two person method..... don't feel like spending $ on a bleeder kit.
There are many DIY links arround... like Stoptech's
But if you're not comfortable, it's not expensive to get it done at a garage.
Oh & you can't afford me... LOL (I can eat & drink a lot)
Old Apr 10, 2006 | 09:42 PM
hayaku's Avatar
if you're gonna do your own brakes, I highly reccomend speed bleeders. Since I have StopTechs I've got 8 bleed screws to deal with instead the standard 4, so the Speedbleeders save me a bunch of time.
Old Apr 10, 2006 | 10:16 PM
InTgr8r's Avatar
Thanks.. good tip
Old Apr 10, 2006 | 11:00 PM
roko's Avatar
When you have 2 bleeders per caliper which one do you bleed first, outside, inside, or does it matter?
Thanks
Old Jun 7, 2006 | 01:58 PM
johnadlertech's Avatar
Thanks
I want to know too.
Old Jun 13, 2006 | 09:04 PM
dp04's Avatar
You should always bleed the outermost component of your system first..Same principle used with the calipers. Furthest from the MC.
Old Jun 13, 2006 | 09:47 PM
afr0puff's Avatar
Supa Dupa Moderator
I think I read somewhere that it really isn't necessary on modern ABS systems. Although I still practice the method you mentioned. Just thought I'd bring it up for debate, if there is one at all.
Old Jun 14, 2006 | 12:24 AM
hayaku's Avatar
Here you go:
http://www.stoptech.com/tech_info/wp...edbrakes.shtml
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Patrick Bovee
Aug 7, 2015 11:16 AM
RedBaronK
Jul 27, 2015 03:19 PM
itschuckster
Jul 25, 2015 08:07 AM
