d spec adjustment
Old Apr 10, 2006 | 11:37 PM
mondo's Avatar
d spec adjustment
Got my shocks and springs put on. The shop worked late and I didn't get the manual on adjusting the shocks (couldn't find anything on the net).
The mechanic said he adjusted them all one level over the middle adjustment. I've noticed the front is way stiffer than the back and I'd like to back it off and see how it feels.
Do I have to loosen the double bolts on the threaded rod before adjusting? I assume counter-clockwise is softer, right? Does it click or do you have to remember how many turns?
Any help?
Old Apr 11, 2006 | 12:49 AM
kenchan's Avatar
You have to remove the cap on the piston shaft. then drop your adjustment tool (bascially an allen key with ****) and turn it ccw for soft. there is no
click. you need to turn it based on the tool's reference line on the top.
Old Apr 11, 2006 | 01:27 AM
mondo's Avatar
Thanks!
Better stop by the shop tomorrow and see if they still have the tool etc..
Old Apr 11, 2006 | 01:04 PM
kenchan's Avatar
this is what the tool looks like:
Old Apr 12, 2006 | 01:02 AM
mondo's Avatar
Thanks Kenchan, they put it in my glove box.
My front shocks were on max firmness, set it halfway and it rides better. Guess there's no real way to get to the back shocks without unbolting.
Old Apr 12, 2006 | 01:42 AM
kenchan's Avatar
^ right, you need to jack up the car, remove the wheel, remove 2 bolts
at the top mounts of the shock, pull down, remove the cap on the shaft
like you did on the front,and adjust the stiffness.
Old Apr 12, 2006 | 01:44 AM
kenchan's Avatar
btw, tokico apprently started selling extenders for the rear adjustment...
you can drill a hole into the trunk area and turn the dial from inside the
car. but, once you set the dampness you won't be changing it that
often so unless you're tracking the car on weekends, just play with
the adjustment without the extender. i had to adjust it maybe 4 times
to get it just right.
Old Apr 12, 2006 | 01:48 PM
FenixL1P's Avatar
a fellow member, myst, who has d-specs with z-springs mentioned to me that if i had the reclining rear seats it would be an easy adjustment for the rears...
i took a ride in his car to hear the hks muffler prior to buying it and the d-specs seem to make the car well planted in turns and during acceleration...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
