Must use D-specs with 350Z H-techs
Old Apr 17, 2006 | 05:21 PM
Luv2xcelR8's Avatar
I want to lower my 2006 g35c with stock OEM 19's and i want to know if i jsut do the 350z springs if it will hurt the suspension later on.....should i get d-specs also?
-thanks-
Old Apr 23, 2006 | 11:30 AM
Gsedan35's Avatar
You'll be fine on your oem shocks since having oem 19's on your 06 confirms you actually have the sport suspension on your coupe. Though I would trim the bump stops a bit front and rear. Now that is not to say that you will not get your monies worth with D-specs, they are a really good shock and represent a pretty good upgrade even against your sport shocks, just can't say with your spring choice that their is any driving need to ditch the oem shocks.
Old Apr 23, 2006 | 06:22 PM
haze's Avatar
Sry to jack the thread a bit, but what does trimming the bump stops do?
Old Apr 23, 2006 | 08:27 PM
Tweaksalot's Avatar
+1 ^^
Old Apr 24, 2006 | 02:14 AM
Andy2434's Avatar
I have come to the same conclusion. My Z Tein H-Techs should arrive sometime this coming week. I decided not to spend the monies for the D-Spec 9's at this time, since I am riding on the sports tuned suspension oem shocks. My only regret is that I will need to get back to front shock/spring set-up again at a later date.
Old Apr 25, 2006 | 02:17 AM
Gsedan35's Avatar
When you lower the car you reduce the shocks piston stoke distance or bump travel. Trimming a little bit off the soft rubber insert inside the dust cover's where they are located isn't a bad idea. What your doing is improving the odds your going to avoid any secondary issues associtated with bump stops touching all the time and effecting ride and handling elements. The more the bumpstops do touch, the more that's a very bad thing. Though we do not want to trim too much.
Old Apr 25, 2006 | 09:14 PM
Andy2434's Avatar
My Z Tein H-Techs arrived this afternoon. The notes include detailed diagrams recommending cutting the bump stops.
Old Jan 23, 2007 | 07:12 PM
GThIrtYFiZle's Avatar
Hey bringing this back to life. Did anyone actually cut the bump stops with the 350 Z H Techs. I didnt, because the picture diagram showed and bigger bump stop and the G35 with the spoty suspension bump stop already looked really small, so i decided not to touch it. What have you guys done.
Old Jan 25, 2007 | 03:34 PM
Slick 6MT's Avatar
Bump for you because my H-Techs will be here in a few days!
Old Jan 25, 2007 | 04:11 PM
I dont know if you want a suggestion. I did some research and found that most people with H techs for the Z have not cut the bump stops. I also didnt, and wasnt sure if I had made the right move, but after searching, I noticed most people havent. You will love the H techs.
Old Jan 25, 2007 | 04:16 PM
Slick 6MT's Avatar
Thanks for the reply. I can't wait to get mine on the car!
Old Feb 5, 2007 | 02:21 PM
Luv2xcelR8's Avatar
Wait so if i get 350z htechs and stick with the stock sport suspension there will be no damage even after like 10 years?
Old Feb 5, 2007 | 02:24 PM
Slick 6MT's Avatar
Nobody said that. haha
There are a lot of factors that are involved in that.
Old Feb 5, 2007 | 02:29 PM
dream_G35's Avatar
i have a coupe with sport suspension and switched out the springs for htechs a few months back, also added stillen sways and front and rear gt spec bars, ride is great. Only thing is now i think i got used to it and everything feels soft again. It might be just me getting too used to the suspension OR the shocks are going. so ill b getting dpecs or coilovers pretty soon to see if it fixes this.
Old Feb 5, 2007 | 02:36 PM
papiloco21's Avatar
i just installed Z htechs plus '06 Z shocks/struts, left the bumpstops alone, car drives great.
