Greddy 350z Coilover Installed Large Pix
Old Apr 22, 2006 | 11:09 AM
denverb's Avatar
Greddy 350z Coilover Installed Lg || UPDATED Install PIX ||
Install
Before
After
Custom cut through in trunk
Adjust Dampness under hood
Big ups to Ralph and Jack @ http://www.delegance-autosports.com for doing a great job. These guys specialize in G's and take pride in their work. This was not a messy rush job. I highly recommend them for anyone in Florida.
If you guys have questions fire away and Ill try to answer them all.
Old Apr 22, 2006 | 11:24 AM
denverb's Avatar
I tried to drive on the same roads to test I havent driven much (600 miles). If I had to pick a number Id say its about 40% stiffer with sway bars and coilovers. Its not horrible but you wouldnt want to drive on a road under repair for long distances! With that being said the up side its on rails it really sticks now.
1.2 Rear
1.8 Front
The front bumper/kit is 5.75 inches off of the ground. Basically just makes the alignment rack @ the dealer.
I dont like the "tucked look" so for me this is plenty I also wanted to stay in alignment spec. Also I can have a full car and not rub.
One thing I didnt mention is that both Jack and Ralph were very pleased with the quality of this coilover. I had not seen anyone with this on this forum and at first I was worried!
Old Apr 22, 2006 | 02:54 PM
sen_jen's Avatar
Meatshake Enterprise
cool. isn't it kinda soft? the rates are for a 350z which is lighter than the G.
Old Apr 22, 2006 | 03:04 PM
sen_jen's Avatar
Originally Posted by schiffdog
So set straight if im wrong. After adding the coilovers you didnt have to make any adjustments to camber or toe?
the reason he may not have had to do any adjustments to camber or toe, is because he set the vehicle at a height in which it didn't alter those settings excessively.
Old Apr 22, 2006 | 04:11 PM
denverb's Avatar
no it was way off I had it aligned at the dealer and they were able to get it back in spec. I have the stillen dual kit for the back and the stillen front camber kit.
I wouldnt say its "soft" by any means. That was the reason I went with this kit ..to avoid it being to rough. If you look at the spring rates its a bit softer than the cs tein. regarding the weight issue well that may make a bit harder than if the kit was on a 350?? not sure
Old Apr 22, 2006 | 04:14 PM
dcam's Avatar
Looks nice.
Old Apr 23, 2006 | 01:49 AM
truplay8's Avatar
THE BATMOBILE
wow what a difference.........looks great.......love the C4's
Old Apr 23, 2006 | 11:25 AM
Gsedan35's Avatar
Huh Greddy's web site plainly show's that the front spring rates are well over CS spring rates,.....560lbs vs 392lbs. Your seller pointed out incorrect specs for the 240SX application. Though I'll bet that the rear rates are either 448lbs or 392lbs.
http://www.greddy.com/prod_coil_over_sus.htm
Old Apr 24, 2006 | 08:19 AM
denverb's Avatar
To be clear I bought these on my own and I dont claim to be an expert! Maybe I looked at the wrong ones but this link does not provide info that I see to say otherwise.
Old Apr 24, 2006 | 11:22 AM
vipv35's Avatar
car looks good man.
Old Apr 25, 2006 | 01:51 AM
Gsedan35's Avatar
MAKE MODEL YEAR NOTES PART# LIST$
NIS 240SX 1995-98 adj. upper, F8K-L200, R6K-250 14022201 $1,580.00
NIS 350Z 2003-on F10K-L200, R8K-L240 14022206 $1,780.00
Ok, I thought for sure your the buyer of the used set sold here, sorry. In any event the link does plainly say the front springs are 560lbs and now that I see it, the rear's are 448lbs, spring rates are built into the spring part numbers in Kg figures.
Old Apr 25, 2006 | 01:41 PM
denverb's Avatar
Hmm Ok
