stillen sway pic
Old May 16, 2006 | 08:42 PM
Dakkerz's Avatar
Originally Posted by bleezo3
I am looking to get the Stillen sway bars. Does it really make a big difference in handling? What's the best setting?
I've had mine for a week now (med/med setting) and I noticed a huge difference when corning aggressively. Car feels like it is stuck to the road, more neutral feeling in fast turns. Great mod for small price.
Old May 18, 2006 | 01:51 PM
Espresso's Avatar
Originally Posted by dklau33
For the Stillen bars you need to get the Prothane Poly Bushings.
03-04 350Z Front 34mm Bar #14-1115
03-04 350Z Rear 21mm Bar #14-1116
The Stillen bars are a bit bigger than stock but these bushing still work no problem.
You can't use your stock bushings?
Old May 18, 2006 | 01:58 PM
Hexxum001's Avatar
+1,000,000,000
I have mine also set at med/med. What a great mod at a very affordable price.
Old May 18, 2006 | 01:59 PM
Hexxum001's Avatar
Yes, you acn use the stock bushings. I inquired with Stillen about getting polyurethane bushings and they said it is not neccesary. The stock bushings work fine.
Old May 18, 2006 | 02:19 PM
g35rcr's Avatar
i went hard/hard on mine but also i have more meat on my tires...i love how it grips now...really puts to use those 255's and 295's on the wheels
Old May 29, 2006 | 02:26 PM
dream_G35's Avatar
is it a very very tight fit or will it fit just right....
Old Jun 6, 2006 | 09:43 AM
cicada06's Avatar
How easy of an install is this? I just got mine yesterday and thinking about installing myself.
Old Jun 6, 2006 | 01:04 PM
cato's Avatar
SouthernComfort Moderator
The stock bushings work perfectly, don't let anyone tell you differently.
Attached Thumbnails stillen sway pic-117_1751_resized.jpg   stillen sway pic-117_1765_2_resized.jpg   stillen sway pic-117_1773_resized.jpg
Old Jun 6, 2006 | 01:17 PM
kenchan's Avatar
how are all your endlinks holding up?
my rear are starting to rattle over uneven pavement at slow speeds.
(I have a spare set in the garage....just seeing how much longer it would
work)
Old Jun 6, 2006 | 03:17 PM
dream_G35's Avatar
same here^^ i put everything on well.....but i still hear a rattle onver bumpy roads. love the way it feels, handles great. I put it on med.med. front and med.stiff. rear
Old Jun 6, 2006 | 07:41 PM
cato's Avatar
My endlinks came loose right after the Ragin Bull Texas Stampedee II, but that was some awefully feirce driving! Had em tightened 1.5 years ago and have been solid ever since...
Old Jun 6, 2006 | 08:52 PM
kenchan's Avatar
the bolt and nuts are tight. the joint is where the rattling is coming
from due to premature wear.
My set up is currently at front: soft / rear: hard
the fronts endlinks seem to be holding up well.
Old Jun 6, 2006 | 09:35 PM
RBull's Avatar
Rated M
work)
How many miles before they started to protest?
Old Jun 6, 2006 | 10:19 PM
kenchan's Avatar
had it on med setting for about 4k miles...then switched over to hard
setting... i started noticing the noice after about 4k miles switching to
hard setting.
when it starts rattling consistently over uneven pavement over 20mph
im going to retire them and swap with new ones i have.
right now it rattles between about 3-15mph.
Old Jun 7, 2006 | 07:19 AM
  #30
RBull's Avatar
Rated M
Thanks, I'm only a medium both f&r so we'll see what happens there.
