stillen sway pic
Old Jun 7, 2006 | 10:06 AM
  #31
cato's Avatar
SouthernComfort Moderator
Originally Posted by kenchan
the bolt and nuts are tight. the joint is where the rattling is coming
from due to premature wear.
My set up is currently at front: soft / rear: hard
the fronts endlinks seem to be holding up well.
My Stillen sways are set up the same as yours, soft up front and stiffest in rear. I have had them this way for around two years now.
Old Jun 7, 2006 | 01:56 PM
  #32
kenchan's Avatar
^^ you probably don't take the corners fast enough. lol.
will see how things go.
Old Jun 9, 2006 | 02:17 PM
  #33
ryanwiggum's Avatar
how are all your endlinks holding up?
my rear are starting to rattle over uneven pavement at slow speeds.
(I have a spare set in the garage....just seeing how much longer it would
work)
I'm getting stillen sways installed soon, should I replace the endlinks as well? I have 32,000 miles on my car
Old Aug 23, 2006 | 11:12 AM
  #34
shimmy's Avatar
For those who went to the Stillen Open House, how did you guys find out about it? I want to go next time and live in the area.
Old Aug 23, 2006 | 02:02 PM
  #35
Ralph0064's Avatar
you guys have mentioned what settings you have your sways set at, but what is the driveability outcome? in other words, how does the car react with soft up front and hard in the rear? ie: tends to oversteer more, or is it neutral, understeer etc.
Old Aug 23, 2006 | 02:35 PM
  #36
cato's Avatar
I have my Stillen sways set soft in front and stiffest in rear. It drives very well balanced. The rear end has never swung out on me, except on wet roads when accelerating hard.
Old Aug 24, 2006 | 01:55 PM
  #37
Dan_K's Avatar
How is this setup hold up? I wanted to do Soft Front and Hard Rear, but some people said it might be too much. Does the car oversteer more easily now? Is this ok for the initial setup?
g.spot
May 9, 2016 10:54 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
alexbenz
Sep 26, 2015 11:30 AM
hawaiian5
Engine - Intake/Fuel
Sep 20, 2015 07:12 PM
