ArizonaZCar Wilwood 4-Pot Front BBK Installed
on
Nothing too special. Make sure you have a breaker bar and maybe even a pipe to go over your breaker bar. The bolts holding the OE caliper to the spindle are torqued at around 110 lbs/ft. You'll want a good torque wrench for sure and also some flare nut wrenches for the brake lines and caliper fittings. You'll also need a certain size allen wrench to undo and redo the caliper bridge bolt.
Darren,
Awesome setup. I'm surprised to see that little of a clearance on your 5Zigens. I saw pictures of 6-pot Wilwood fronts on stock sedan wheels. 6-pot must be narrower than 4-pot.
In regards to brake bias, I wonder if EBD which our cars are equipped with can accomodate for bias changes. Any thoughts on that?
on
Andrew,
Thanks. The 6-pot calipers are actually wider than the 4-pots so maybe you saw 18" stock sedan wheels? Because my wheels are 17". There is no way the stock 17 x 7 +45 sedan wheels would clear these brakes. As for the brake bias and EBD that is a good question that only someone a lot more technical and knowledgable than I could answer. Interesting thing though is that I read this article in Sport Compact Car not too long ago. They had a project Scion Tc they were working on and were doing a brake upgrade. They did all this work to try to maintain the correct bias but at the end of the article they said it didn't matter since the electronic brake management on that vehicle would just override and accomodate for bias changes. Could it be the same for us?
arizonazcar.com 4-Pot Front Brake Kit
I'll be updating my website shortly to offer the 350Z/G35 Front BBK with the 4-piston Forged calipers and 13" rotors for $1095 for the pair complete.
I have them in stock.
Thanks very much,
Dave
ARIZONA Z CAR
2043 E. QUARTZ ST.
MESA AZ 85213
480-844-9677
dave@arizonazcar.com
www.arizonazcar.com
Thanks very much,
Dave
ARIZONA Z CAR
2043 E. QUARTZ ST.
MESA AZ 85213
480-844-9677
www.arizonazcar.com
Originally Posted by dklau33
I don't see any reasons why runflats wouldn't fit. Just depends on if the manufacturers make them in the proper tire size for the wheel. I'd suggest sticking with your current size of 235/50/17 or 245/45/17. I know the 245/45 size has some choices for runflats.
If you're worried about flats then either have a can or two of the fix-a-flat stuff or get a wheel that will fit over the bbk as your spare. That's what I'm planning on doing when I decide to upgrade my rears to the RacingBrake OE Caliper Rear kit. Are you planning on getting a 4 corner kit?
on
Originally Posted by cato
I wonder if my Pirelli 235/50 17s will mount on the 17X8s? Since it looks like I must buy new wheels to fit over the BBK, the $2500 lawsuit money will need to pay for 4 new wheels and the Arizona front wilwoods. There will be no money left over for the rears.
on
cato: if I were to get a flat in the front I would just throw the spare on the back and move the back wheel up to the front. More than one flat and then I'm screwed but that's regardless of the brake kit anyway... lol
My wheels are 5Zigen FN01R-C. Cost $200 each from Discount Tire Direct. Only weighs 17 lbs per wheel which is lighter than the OEM sedan wheels by about 4 or 5 lbs.
Silver Wheel
Flat Black Wheel
Gloss Black Wheel
Only the 4-pot caliper will fit the wheel in my size. The 6-pot caliper won't. If you order these same wheels I'd suggest you get 17x8 +35 offset which are the ones I've linked above. Those will definitely clear the 6 or 4 pot caliper.
Silver Wheel
Flat Black Wheel
Gloss Black Wheel
#30
on
I contacted Discount Tire and got a quote on the wheels. The sales guy told me the 17X8s weigh 19 lbs each. I'm gonna buy them anyways. My Pirelli 235/50 ZR17 will indeed fit these bad boys, so I will save myself the cost of 4 new tires.
