Canada Serving Canada.
my g is already rusting
Old Jun 14, 2006 | 02:15 PM
35bills's Avatar
Do you know that your car is rusting from the moment it is built?
I heard this from the president of Krown on a TV show.
Old Jun 14, 2006 | 02:26 PM
PDT's Avatar
PDT
Originally Posted by picus112
Hey guys; the reason it isn't covered is because it's a chip. Any car with a chip will rust in a couple days exposed to the elements. It's a bummer, but at least our hoods are aluminum and won't rust. OK, how to take care of it.
1) Clean the area really well with alcohol and water. Regular rubbing alcohol mixed 50/50 with water in a spray bottle, spray, wipe, repeat. Make sure to really soak the chip.
2) This is optional. Get a rust pen from Canadian Tire. It's a pen with glass tips at the end that act like sandpaper. Put it in the chip and spin it to get most of the rust. I would personally do this if the rust seems substantial.
3) Also, get a rust converter from CT. I showed Bill this at the meet; and Edmond in person, it's a neat product. Just lather the area with it (wear gloves, it's gross), let sit for about 10 min, repeat 2-3 times, and the leftover rust turns to primer.
4) Get a primer pen (CT again), it's a ball point pen that spits out primer. Fill the chip.
5) Wait 4 hours.
6) Fill chip with touchup, repeat until level (wait 4 hours in between coats).
7) Success.
Great thanks for the DIY Kevin!!
Old Jun 14, 2006 | 02:46 PM
Picus's Avatar
Staff ALUMNI
Originally Posted by Balzz
Whoa...what's it called? What section of CT would I find it in? This would rock to clean up the surface rust in the RX7.
Hrm, the bottle is downstairs, I forget the name. It's in the paint section near all the touchups/sandpaper. It says "Rust Converter" right on it, small bottle (8-10oz) - there will be three or four varieties, all with the same effectiveness. You can buy larger amounts for bigger jobs. I'd say you use about one ounce per 4x4 inch area or so. You really do need to soak the rust and let it sit for a bit. It won't hurt the paint.
As for rust in general - cars are metal, they will rust. With modern paints and aluminum and plastic parts rust is becoming less and less an issue, but since we're all in Canada we know firsthand what a pain it still can be. I take my car in and have Krowne to the bottom every year, and obviously I try to be aware of chips in spots that aren't obvious. On our cars this is door jambs, wheel well lips, bottoms of fenders, roof lip, gas cap. Fender/door chips are fairly obvious, and hood chips won't rust.
Just give it a once over every few weeks and fill any chips you see with primer, of if you're lazy just fill them with touchup paint. Keeping the metal from being exposed to the elements is the key.
Old Jun 15, 2006 | 06:57 AM
RBull's Avatar
Rated M
Great chip fix it advice Kevin.
Deane
Old Jun 15, 2006 | 09:43 AM
giddyup69's Avatar
Thumbs up
is the rust converter safe on paint? what kind of solution is it (i mean is it like paste... won't run)? my chip in on the side of the trunk lid just below the spoiler (have no clue how it got there). if it's a liquid form how do u suggest i keep the solution on the small rust spot? i'm gonna run to crappy tire on my break and see if i can buy all this stuff. thanks for your help. hopefully i'll be able to get to it by tomorrow.
Old Jun 15, 2006 | 10:33 AM
35bills's Avatar
The rust converter is a liquid so it will run a little.
Perhaps you can dab an old rag and wipe the chip out. Do it a few times to ensure the chip is saturated with the solution.
Your chip is in a tough spot. I have one on the edge of my spoiler( how that got there I do not know), luckily it didn't chip through to the metal.
Read the instructions carefully!!!
Good Luck with the fix up.
B.
Old Jun 15, 2006 | 11:16 AM
Picus's Avatar
Staff ALUMNI
The coverter is safe on paint, so if it runs that's not a huge issue. Like Bill mentioned it's kind of a viscous liquid; try putting some on a q-tip then dabbing it in the chip. You'll have to repeat a few times (let it sit 5-10 min each time), the rust will turn a grey-ish brown color as it turns to primer.
Old Jun 15, 2006 | 11:23 AM
elau's Avatar
Wow, I am so glad to see so many of you have the same problem as mine. I posted my b!tching over 6 months ago and called my G a rust bucket and some a-hole members here called me a G basher. My rust is all along the inner trunk lid. It appears they did a poor job on the primmer before painting.
I have not gone back to the dealer yet and from the way you guys talk, guess I will get very little help from them as well.
Old Jun 15, 2006 | 11:40 AM
35bills's Avatar
elau,
I think with your rusting problem, Infiniti would help out.
Have the dealer check it out.
It sounds like a warranty issue.
Good Luck.
Bill
Old Jun 15, 2006 | 12:02 PM
giddyup69's Avatar
it kinda seems funny that we're all experiencing rust in the same general area. i think your right... whoever was manufacturing those trunk lids seems to have done a shotty job. i'm assuming that nissan uses galvanized steel so i'm a little surprised that the rust has appeared this quickly. when i had my older acura i know i had a few rock chips that i never repaired... but there was never any signs of rust. i'm in stainless steel now and used to work for anotech/decoma... so this all seems a little weird to me. as my op read, i originally thought it was some brown dirt and not rust!
Old Jun 15, 2006 | 01:12 PM
giddyup69's Avatar
ok.. went out and bought the goods at crappy tire.
prep pen - $8.49
rust converter - $8.49
primer pen - $9.99
pics below for reference... and yes... the rust converter bottle had leaked... in fact they didn't have a single bottle that hadn't exploded in some funny fashion. by the remaining shape of the bottle... i start to really wonder how safe this is on the paint
Attached Thumbnails my g is already rusting-pen.jpg   my g is already rusting-rust.jpg   my g is already rusting-primer.jpg
Old Jun 16, 2006 | 07:44 PM
giddyup69's Avatar
Thumbs up raging success
just want to say that i tried out the directions offered by picus/kevin... and i must say that i am extremely pleased with the results.
i washed the car tonight and then swiped the rust areas with some rubbing alcohol. immediately u could see some of it come off onto the q-tips. i then used the prep-pen (or sanding magical doo-da)... this is what really did the trick. i used light pressure and a gentle sweeping motion and all the rust came off with little effect to the surrounding paint. that stick really does it's job. i then applied some of the rust-neutralizer (but i honestly don't believe i had to).... followed it up with some primer... and tomorrow morning i'll fill in the area with touch up paint. should look good as new.
i highly recommend the prep-pen as it really does seem to do an excellent job. thanks again to all that helped me out in this situation. may the rust now R.I.P.
Old Jun 16, 2006 | 07:54 PM
Picus's Avatar
Staff ALUMNI
Thumbs up
Now you just need to learn how to wet-sand!
Old Jun 16, 2006 | 09:18 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^^ I understand Colin has a deal on some unigrit blocks
Old Jun 18, 2006 | 05:13 PM
  #30
Iso Octane's Avatar
I have one too. Don't know how it could chip there. Gotta be careful with that luggage I suppose.
Yes. The car is unclean at the moment.
picus, thank's for the advice. Much appreciated.
