Canada Serving Canada.
Storing the Car for winter :( but need advice
Old Oct 8, 2009 | 06:45 PM
  #31
musti82's Avatar
Originally Posted by Asad_A203
Depends on the temperature. I wouldn't want to stress the car if I didn't need to crank it in under optimal conditions.
As a side note, do you guys just disconnect the negative terminal or actually pull the battery out? I am going to go about doing it this weekend but I imagine I would need to remove the plastic trim to gain access to pulling the battery out.
my underground park is pretty hot actually at least in 20 C. I guess it should be fine. $215 X 3-4 months savings is pretty damn good im not adding up the gas cost
Old Oct 9, 2009 | 08:18 PM
  #32
shilohap's Avatar
I store my car in a shipping container. Its dry, clean and a about 10 inches off the ground so I ramp into it. I change the oil, fill up the gas tank, leave the parking brake off, disconnect the battery. I park it for five months and I start it once a month with the doors of the shipping container wide open of course and let it run for 20 mins enough for the thermostat to open and give the pedal a periodic rev.
Old Oct 9, 2009 | 09:05 PM
  #33
TomieG's Avatar
Quick question, why would one leave the parking break off? Even if its a 6speed?
Old Oct 10, 2009 | 09:48 AM
  #34
RBull's Avatar
Rated M
^brake may tend to seize (rust on the inside park brake drum) or in the line itself. Never a good idea to leave it on for a prolonged period.
Old Sep 25, 2011 | 05:41 PM
  #35
skidz88's Avatar
Sorry to bring this back but I figured it'd be better than starting a new thread.
I'm looking into storing my car for the winter, trouble is it'd be outdoors on the driveway. I have a double garage home but due to the unique way the builder constructed the garage you can only get a Civic or something in it.
I found this: http://www.canadiantire.ca/AST/brows....jsp?locale=en
Could I get away with something like this? Maybe erect it over top of a tarp. Any other tips specific to storing a car outdoors? Should I scrap the whole idea and look into paying monthly for indoor storage?
Old Sep 26, 2011 | 08:46 AM
  #36
GEE35FX's Avatar
Faisal, I would be concerned with the snow load and the effect of strong winds on that portable garage.
Old Sep 28, 2011 | 10:41 AM
  #37
SANTOS29's Avatar
^^ I actually had to use one a portable garage, while the garage was getting constructed, you have to make sure it is secured to the ground, cause I though ours was secured enough and found the damn thing sitting accross the street on a windy day, about the snow load it handles it with no problems, I used it for a winter and than gave it away to my neighbour in the summer, he is actually still using it for his ATVs; it has been through quite a few big snow falls, one thing I did was use tapping screws on all the joints to make it more secured cause without them the frame felt really flimsy, hope this helps.
Old Oct 4, 2011 | 06:59 PM
  #38
skidz88's Avatar
Well finally made a decision, found some storage for $75/month. Indoor, secure, gated.
Old Dec 13, 2012 | 02:25 PM
  #39
g35shane's Avatar
Kick starting this thread again as I'm about to store my G and had a QQ. I'll be storing in a garage (non heated) and am wondering if I can get away with not removing or disconnecting the battery if I start it up every 2-3 weeks? If this will work how long should I let it run for?
Old Dec 16, 2012 | 11:23 PM
  #40
Sylvan lake V35's Avatar
So instead of giving a 10mm bolt two twists to unhook the negative cable you're going to go start the car every two weeks and let it run for 10 min
Old Dec 17, 2012 | 02:52 PM
  #41
Ejoe19's Avatar
^Positive or negative? I've always just undone the negative cable and never had any problems
Old Dec 17, 2012 | 09:54 PM
  #42
Sorry, you're correct always negative first and negative for storage.
Old Dec 19, 2012 | 02:17 PM
  #43
ZGagnon's Avatar
bedtime
but will be getting work done all winter
Old Oct 29, 2013 | 11:46 PM
  #44
thirtyfizzle's Avatar
Bump instead of making a new thread. About that time to store the G's
Old Jan 22, 2014 | 09:57 AM
  #45
netcbc's Avatar
I've been starting my car biweekly but it's starting to be a pain.
So disconnecting the battery will keep it alive? What are the downsides? I guess no alarm and losing radio settings?
Thanks
