Canada Serving Canada.
Automatic shift console to Manual look?
Old Jan 14, 2008 | 09:47 PM
Asad_A203's Avatar
Originally Posted by RBull
The ring shown on that first pic isn't quite right (a bit big). On the 6mt it actually is flush with the console.
I think it might be because he was just using the pre existing circle from the automatic shifter and trying to fit it in. I am not positive if the 6MT and AT have the same size cutout though; does anyone happen to know?
Old Jan 14, 2008 | 09:53 PM
jjyellow's Avatar
Old Jan 14, 2008 | 10:04 PM
Asad_A203's Avatar
Thanks. I saw the FX swap; but the chrome doesn't fit well. Will check out the 350Z one. Saw a bunch of sucessful swaps with the 350Z.
Ah screw it I will just try it out. I will PM Jason to get a price for the ring and see what happens. Only ten bucks... This guy also has a much nicer shift **** (40 bucks) I think than the MOMO IMO; will probably use that as well or go with the same one that G35 has.
If the fitment is bad; I will just but the 06 MT Center console; and make it sit right.
Old Jan 14, 2008 | 11:46 PM
SDGeneralCounsel's Avatar
Possibly, but that's what the guy that owns the car in the OP's pic said. Here's the link for the part
http://www.trademotion.com/partlocat...layCatalogid=0
Originally Posted by jjyellow
I saw this when the thread first started and thought it looked awesome. It really can't be done unless you go with the MT ring
Old Jan 14, 2008 | 11:53 PM
1, the dimentions on the mt console appear different to me than the AT ones. Also, the picture is one of a MT supra, so the shifter **** wont work for you. It's a total ricer **** too. Go JDM or nothing. Do some research and then ask questions.
Old Jan 15, 2008 | 08:18 AM
RBull's Avatar
Rated M
Not following what you are trying to convey when you say possibly. What did the owner of the OP's pic say?
Also not one of the three items in the link you provided appear to be the correct part according to the diagram. Why is there a different part listed for something that is the same year?
Old Jan 15, 2008 | 08:19 AM
RBull's Avatar
Rated M
Doesn't appear to be based on the fit of the pic you provided.
Old Jan 15, 2008 | 09:27 AM
617G's Avatar
CFW (Carbon Fiber Whore)
While the 350z one looks really good, you're not going to be able to do that on a g35 because the base is different. The 350z has the ring while we do not. The only way to make it look like that is to take off the base and put in some kind of ring like the OP has been talking about.
Or, you can do what I did and slide the boot under the base. Just make sure you don't get a boot with piping because it makes it a PITA and the piping is too thick.
Old Jan 15, 2008 | 11:23 AM
yes the cutout is roughly the same, but.... you would need the entire center console or you can try to use the MT ring. I'm done with this thread. You aren't listening and you clearly haven't done any research.
Exactly, and their is no method that I know of besides doing the MT ring method I mentioned above. OP, rip the center console apart and see for yourself. It will answer all of your questions.
Here was the thread I found from a while back that I got the ring method from
https://g35driver.com/forums/showthr...=103522&page=4
Old Jan 15, 2008 | 01:21 PM
RBull's Avatar
Rated M
No worries. Not sure why you seem to be offended since that is not my intention. I'm only suggesting the ring shown in the pic is not mounted the same as it is in an MT.
In any case you haven't answered either of my questions. From your response above I take it you also agree the ring for the MT and AT are not exactly the same.
Old Jan 16, 2008 | 12:20 AM
Asad_A203's Avatar
Haha. It is an AT Supra . That is an automatic shifter ****. I personally prefer that style of it over the MOMO ****. I like the IMPUL **** as well.
Well after further inspection; the MT has a much bigger circle cutout thing like you said; the dish will probably end up sticking out like that because of the size of the dish but what if I got a 350Z AT Shifter ring and placed it instead? I am pretty positive they use the same shiftplate dimensions but the circle thing is just extra. Would seem like a tight fit though.. To get the fit of a MT; will require two different panels; getting a bit troublesome for a conversion.
I will open up my console next week and check it out for myself.
Old Jan 16, 2008 | 05:12 PM
Asad_A203's Avatar
Do you know what part I will need? I was going to order today; but there are 2 different "rings" parts for the MT; not sure which one is the one that will serve my purpose.
Old Jan 16, 2008 | 06:53 PM
The-Dream's Avatar
I'd pay someone $300 for labour not including parts to do it for me. You have to have done it before and have some experience though. Any takers? This mod is totally sweet.
Old Jan 16, 2008 | 08:04 PM
Asad_A203's Avatar
Not sure about this mod; it seems pretty straight forward. You remove the dash/console; remove the shift **** so you can lift up the center console; remove the circle shift plate; insert the 6MT one and crimp the leather boot (guy who has done it in the pics says he just popped it in there; nothing else); and reassemble the dash and install the Auto shift ****.
As long as I am only unscrewing a bunch of screws in the interior; and not touching anything mechanical; I think I will be fine. But don't be suprised if next week if I do **** up and post that "XXX is not working after dash removal" .
I will take some pics as I do it though if I get that circle plate and my shift **** by next week.
Old Jan 16, 2008 | 11:17 PM
  #30
The-Dream's Avatar
I'd still rather not touch it myself. Post pictures when you have it done, maybe we can work something out.
