Canada Serving Canada.
Automatic shift console to Manual look?
Old Jan 17, 2008 | 06:12 PM
  #31
Asad_A203's Avatar
Some Progress
Didn't yet order the parts; still waiting for someone to confirm which one I need but I did dissamble the console. Will make a full DIY when I am done; but will show you how to dissamble the center console part if you want to check it out until I get the parts and do it:
1. Engage the parking brake; depress the brake pedal and remove the plastic cover for the shift lock button. I had no luck using my screw drivers so I just used a toothpick to push it in; when you hear the click; shift the **** to "N".
2. Pull the plastic sleeve on your shift **** down. THe part will slide down to the base of the ****. After this; remove the C clip on the ****. Keep the C clip somewhere you will remember; small part and can easily get lost.
[note in picture I tried doing it in Park; will not work as center console will not move unless shifter is in N]
3. Push the button and lift the **** straight up; you will have the shift **** now dislodged. You can add your MOMO or other AT shift **** if you are not looking at adding a shift boot.
4. Open up the ash tray(my coin holder) and the cup holder. Remove all your junk inside there. Open your arm rest; from the back of the center console; lift straight up. Your center console should come up from the back.
5. Push the center console gently towards you; there are no screws just a clip. When you feel it disengage; manoveur the change holder to get out of the HU area. Disengage the wiring for the seat warmers (if so equiped) and the lighting for the shift plate.
6. You will now be able to lift the center console and place it somewhere; preferably a MF towel on your seats and lay it down. The shift circle for the AT is attached with two screws and is connected to a harness. I think you will just need to remove those two things; and you should be able to remove it and place the new shift circle.
7. Reassemble. To be continued
Everything seemed to work fine; except I think I might have moved my shift ring too far when I was reassembling it because it makes a terrible noise when shifting gears now; probably because of that black plastic thing; I will check it out but anyone have any ideas on what is the likely problem there?
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
RWDguy4238
Sep 30, 2015 12:13 AM
Chauzilla
Sep 27, 2015 04:34 PM
blnewt
Sep 25, 2015 01:48 PM
