Canada Serving Canada.
DS window won't close... ?
Old Mar 30, 2008 | 08:51 AM
Msedanman's Avatar
O.F. Administrator
Originally Posted by whatacar
Tried it this morning Colin, didn't work. But it looked like a good day for a drive, even with the window down, ( when I do it manually without the one touch up it reverts to 3/4)
Later, I found out that with the car on and the door open if I raised the window to the top and shut off the car. When I restarted it to drive, the window stayed up.
I can live with that for now.
Sorry to hear the 'fix' didn't work, Sam, but at least you can get it up and stay up.
(can't believe I said that..... )........
Pretty sure the tensioner is incorrect and needs adjusting....
C.
Old Mar 30, 2008 | 09:12 AM
RBull's Avatar
Rated M
C.
Can't believe it either. LOL. Here's hoping Sam can keep it up.
Old Mar 30, 2008 | 09:39 AM
whatacar's Avatar
Sorry to hear the 'fix' didn't work, Sam, but at least you can get it up and stay up. (can't believe I said that..... )........
C.
Thanks Colin, I'll share your observations with N. BTW which **** (right or left ) adjust the tension
Old Mar 30, 2008 | 09:44 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
LOL.....
Old May 26, 2008 | 10:31 PM
whatacar's Avatar
Originally Posted by TIRE_SMOKE96
wow and I was about to make a thread on this too, great info! My DS window is doing the same thing.
I have discovered that if I hold the switch in the up position while I'm driving for 5 ish seconds, I actually hear a click the window will stay in the up position. I'm gonna have it fixed when I get my belts done.
Old May 27, 2008 | 01:30 AM
LR-G's Avatar
dont mean to ask but since windows is the topic anybody here have a cracking/creeking sound when the window goes all the way up.
when my DS window is half way down it sounds like its not seated well when I hit a bump or pothole.
Old Jul 31, 2009 | 09:03 AM
kingrukus's Avatar
whatacar - did you ever manage to figure out what went wrong with your window? I am having the same issue now.
I will try the reset procedure first, but from a bit of research it sounds like I may have a mis-aligned window regulator. Our symptoms however are very similar.
This all started after the 2nd time I cleaned the carbon deposits from my power window motor.
Another issue I am getting is that the window seems to stay stuck all the way down or all the way up, and will stay there unless I open and close the door (providing a vibration to the regulator/motor).
Sorry for bumping an old thread...
Old Jul 31, 2009 | 03:40 PM
whatacar's Avatar
I just use the manual switch by lifting it almost to the limit of the switch. It goes up and stays up. I then release the switch.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
