Canada Serving Canada.
Nitrogen tires fill
Old May 14, 2008 | 10:55 AM
latte's Avatar
Infiniti G35 4 doors sedan
Nitrogen tires fill
At Oakville Infiniti they offer now nitrogen fill for your tires for almost $50.00 when you can do it at any Costco locations for Free.
Old May 14, 2008 | 11:01 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
IIRC some costco only do it if you bought tires... others do it no problem.
Old May 14, 2008 | 11:08 AM
latte's Avatar
I think the charge of $50.00 is way too much for that kind of things... it's simply ridiculous... how one can justify it?
Old May 14, 2008 | 11:14 AM
Swivel's Avatar
Moderator
^^ Yup, when I bought tires for my last car, they did that for me. And put lovely green valve caps on. I put them on my kids' bikes.
Old May 14, 2008 | 11:28 AM
Christian's Avatar
$50 for nitrogen is outrageous.
The green caps have to be better than the garbage supplied by infiniti, those stupid tin caps have fused to my TPMS valve stems twice.
Old May 14, 2008 | 11:39 AM
GEE35FX's Avatar
Guelph Infiniti offers it also now.
I would not waste my money. If it was free then okay.
Now if we could get helium for our tires to make our cars lighter and use less gas
Old May 14, 2008 | 12:54 PM
God|ZIlla168's Avatar
If you guys really want it go to canadiantire 20 bucks to change out to nitrogen and is free forever afterwards
Old May 14, 2008 | 12:57 PM
GEE35FX's Avatar
^^^Thanks Eric. Thats a more reasonable price.
Old May 14, 2008 | 01:14 PM
Swivel's Avatar
Moderator
Interesting, just had them mount some tires on my wife's SUV, wonder if they put in N2? I'll have to check for green caps.
Old May 15, 2008 | 08:06 AM
Chris G35's Avatar
Is it true that you cannot mix oxygen with nitrogen if the tire pressure is a little low?
Also do you need a different type of tire pressure gauge to measure the amount of nitrogen in the tires? (as in you cannot use a regular tire pressure gauge)
Someone told me this over the weekend but for some reason I don't believe them.
Old May 15, 2008 | 08:16 AM
InTgr8r's Avatar
You should top up with nitrogen, but the whole point is that you shouldn't need it very often.
Pressure in my wifes Escape has been good for 6months now.
Same P Gauge is fine, it's still just air pressure that you are reading.
Try not to loose too much when checking.... most of your pressure loss will be due to leakage when checking.
& in an emergency you can fill with normal air (normal air is mostly nitrogen anyway)
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Fire0nic3
Aug 31, 2015 03:18 PM
Jroc2017
Aug 16, 2015 07:16 PM
brian_z
Jul 22, 2015 09:19 PM
