Canada Serving Canada.
Compression rods shot!
Old Sep 16, 2008 | 12:55 PM
sdnpaul5at's Avatar
Both sides are confirmed shot, the clunking noise drives me nuts, does anyone have any spare parts? or should I just get them at the stealership at over $300 a piece, any suggestions, thanks guys.
Old Sep 16, 2008 | 01:11 PM
PDT's Avatar
PDT
I think you can order them from Tony at Riverside for $248 (USD) for the Pair plus shipping here.
I was just told that mine need to be replace again.
Old Sep 16, 2008 | 01:53 PM
sdnpaul5at's Avatar
Crap! again! This isn't a cheap repair, I had complained about the rods at about 109k right before my warranty ran out, they said it was nothing but I got a work order on it, I recently went back to the dealer & they said the compression rods are only covered up until 100k & they could not fix it under warranty, was worth a try though.
Old Sep 16, 2008 | 03:51 PM
RBull's Avatar
Rated M
yeah, too bad you couldn't get them covered. Comprehensive warranty is only 100k 4 years with the power train going 110k 6 years.
Old Sep 16, 2008 | 03:55 PM
absolutg's Avatar
workin...
are you sure it's not just the bushings?
Old Sep 16, 2008 | 06:21 PM
whatacar's Avatar
Here's a link that you may find interesting.
https://g35driver.com/forums/canada/...ump-klump.html
I had my first c rod replaced at 110 for $200 at the stealership. Then my other on at Simone Performance for a reasonable price including an allignment
IIRC, the stealership charges bout 6 bills a side. ( not a full allignment )
There is other info. on the board. Try a search, it's a job a competent shop should be able to do.
GL
Old Sep 17, 2008 | 01:28 AM
Asad_A203's Avatar
Is there anyway to know if your compression rods are on there way out? My G is taking a crap all over me (power windows not working, rough starts) so I am expecting the worst now for everything.
Old Sep 17, 2008 | 07:29 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
GL
^ good advice Sam.
IIRC the bushing kit that is now available is quite a bit less expensive.
Unless the bushing has deteriorated to the point that the c rod is damaged, it's all that's really needed.
Dealers are used to replacing the complete c rod for this issue.
The B.kit is a more recent development and they may not be aware of it.
(or just prefer to charge the extra $ for new c. rods)
Old Sep 17, 2008 | 10:31 AM
sdnpaul5at's Avatar
Can I purchase the bushings seperately? I was told that the bushing is part of the compression rod.
Old Sep 17, 2008 | 11:22 AM
InTgr8r's Avatar
They have to be pressed out/in
Old Sep 17, 2008 | 02:49 PM
sdnpaul5at's Avatar
This guy has an ad on Kijiji, he claims he can get parts for 30-50% off, has anyone purchased anything from him, check out his ad.http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ71314646
Old Sep 17, 2008 | 03:07 PM
InTgr8r's Avatar
Never heard of him.... I'd be a little cautious.
Old Sep 17, 2008 | 03:08 PM
RBull's Avatar
Rated M
^+1
That's the same or less than dealers pay for the parts.
Old Sep 17, 2008 | 04:30 PM
shilohap's Avatar
And I heard the 3.5L in the G is one of the world's ten best engines. Are they talking about reliability or performance? The more I read on these boards the more horror stories I hear.
Old Sep 17, 2008 | 04:35 PM
InTgr8r's Avatar
bushing part numbers....
(2WD) 54570-AC70A
(AWD) 54570-AC71A
