Canada Serving Canada.
Memory Seats
Old Sep 16, 2009 | 12:12 PM
supergino's Avatar
Memory Seats
Hey Guys,
I have the 07 6MT and I just took it to the dealer for the memory seats. They werent working at all (like dead) no lights were coming on or anything but the seats work fine. Apparently the systems arent talking to each other and I need a brand new steering column
Anyway was just wondering, if you programmed the button, do both the steering column and the seats go back to the original position if you press your designated button or is it just the seat?
Thanks for the help.
SG
Old Sep 16, 2009 | 02:27 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
There is memory on the steering wheel too.
...there is no auto egress position for either seat or steering with the 6MT
Old Sep 16, 2009 | 06:21 PM
canucklehead's Avatar
off-topic - but you guys actually use the memory function? i haven't used it once. my seat is on perma-memory since i'm essentially the only driver.
Old Sep 16, 2009 | 07:26 PM
InTgr8r's Avatar
I use it for track setting on 2 & dd on 1
...no other butt in the driver seat but mine
Old Sep 16, 2009 | 08:33 PM
RBull's Avatar
Rated M
I have #2 set for my wife but she's yet to drive it except for the day 1 drive around the block.
I don't use the auto egress. Drives me nuts with the seat going all the way back and wheel way up. If I weighed another 150 pounds and/or was 8" taller I might need that.
Old Oct 12, 2009 | 03:13 PM
prathap's Avatar
Seat slider problem
I have 04 G35 Sedan. Its an A/T model. For some reason, the seat slider doesnt with with the seat memory. For example, when I press memory 1 switch my recliner front lift and rear lift settings adjust normally. However the slider wont move to the desired position. This happens with auto entry/exit system as well. When I take the ignition key out, the seat slides backward giving enough room to exit the car. However, when I place the key in the ignition the seat doesnt slight forward as it should. Does anyone what could be causing this?
Thanks,
PK
Old Oct 12, 2009 | 11:19 PM
blario's Avatar
our sedan has the auto exit feature....both the wheel and the seat go back but you can set that how you want. My wife likes the feature and she is fairly slim but in the coupe, only 1 is programed - for me.
Old Oct 13, 2009 | 09:29 AM
4DGS's Avatar
I use to use the auto exit with my memory seats but got tired of it. Now it stays put.
Old Oct 13, 2009 | 11:02 AM
STCLAIRWEST's Avatar
I love that feature been using since day one. I'm a big guy so it really comes in handy.
Old Oct 13, 2009 | 11:40 AM
TroysG's Avatar
hey SuperGino, does your seat still move?
Have you looked for blown fuse(s)?
Old Oct 13, 2009 | 12:33 PM
4DGS's Avatar
Aren't you like 6'1"?
Old Oct 13, 2009 | 12:59 PM
Yes I am
Old Oct 13, 2009 | 01:30 PM
4DGS's Avatar
I once saw a guy about 6'5" get out of a coupe. I bet he did the seat mod for more headroom lol
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
zcherub
Sep 10, 2015 12:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
