Canada Serving Canada.
Chuckle for the day
Old Dec 19, 2009 | 10:25 AM
  #31
Swivel's Avatar
Moderator
Resulting in A, if yer doin' it right. Haha, okay, moving on...
Old Dec 22, 2009 | 01:44 PM
  #32
InTgr8r's Avatar
Staff ALUMNI (retired)
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/QXAa-1ygTIE&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/QXAa-1ygTIE&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Dec 22, 2009 | 01:52 PM
  #33
Swivel's Avatar
Moderator
LOL, I'd only seen that in written form...I knew it sounded familiar. NOT showing that to #1 son, since he does have a train set.
Old Jan 1, 2010 | 08:42 AM
  #34
RBull's Avatar
Rated M
I can relate to a few of these. LOL
"Tools Explained"
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also, removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, ****!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also, handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use..
Son of a bitch TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a bitch" at the top of your lungs. It is also, most often, the next tool that you will need.
Old Jan 1, 2010 | 09:08 AM
  #35
shilohap's Avatar
Don't forget the open ended wrench the one that tears the skin off the top of your first three knuckles while your under the hood!
Old Jan 1, 2010 | 10:48 AM
  #36
RBull's Avatar
Rated M
^ we've always called that tool the knuckleskinner.
Old Jan 1, 2010 | 11:11 AM
  #37
InTgr8r's Avatar
haha... good ones.
I can definitely relate to some of them.
Old Jan 1, 2010 | 11:18 AM
  #38
Swivel's Avatar
Moderator
I have a garage full of SOB tools. Or at least, I used to. Surely some of them have landed by now and I could go and find them if I tried.
Old Jan 8, 2010 | 06:54 AM
  #39
RBull's Avatar
Rated M
Hope you get a chuckle or at least a grin out of some of these.
1. How Do You Catch a Unique Rabbit?
Unique Up On It.
2. How Do You Catch a Tame Rabbit?
Tame Way.
3. How Do Crazy People Go Through The Forest ?
They Take The Psycho Path
4. How Do You Get Holy Water?
You Boil The Hell Out Of It
5. What Do Fish Say When They Hit a Concrete Wall?
Dam!
6. What Do Eskimos Get From Sitting On The Ice too Long?
Polaroid's
7. What Do You Call a Boomerang That Doesn't work?
A Stick
8. What Do You Call Cheese That Isn't Yours?
Nacho Cheese.
9. What Do You Call Santa's Helpers?
Subordinate Clauses.
10. What Do You Call Four Bullfighters In Quicksand?
Quattro Sinko.
11. What Do You Get From a Pampered Cow?
Spoiled Milk.
12. What Do You Get When You Cross a Snowman With a Vampire?
Frostbite.
13. What Lies At The Bottom Of The Ocean And Twitches? A Nervous Wreck.
14. What's The Difference Between Roast Beef And Pea Soup?
Anyone Can Roast Beef.
15. Where Do You Find a Dog With No Legs?
Right Where You Left Him.
16. Why Do Gorillas Have Big Nostrils?
Because They Have Big Fingers .
17.. Why Don't Blind People Like To Sky Dive?
Because It Scares The Dog..
18.. What Kind Of Coffee Was Served On The Titanic?
Sanka.
19.... What Is The Difference Between a Harley And a Hoover ?! The Location Of The Dirt Bag.
20. Why Did Pilgrims' Pants Always Fall Down?
Because They Wore Their Belt Buckle On Their Hat.
21. What's The Difference Between a Bad Golfer And a Bad Skydiver?
A Bad Golfer Goes, Whack, Dang!
A Bad Skydiver Goes Dang! Whack .
22. How Are a Texas Tornado And a Tennessee Divorce The Same?
Somebody's Gonna Lose A Trailer
Old Jan 8, 2010 | 08:02 AM
  #40
InTgr8r's Avatar
Thanks Deane... LOL'd at most of 'em
Old Jan 13, 2010 | 03:52 PM
  #41
Swivel's Avatar
Moderator
It's a slow day in some little town.
The sun is hot....the streets are deserted.
Times are tough, everybody is in debt, and everybody lives on credit.
On this particular day a rich tourist from back west is driving thru town.
He stops at the motel and lays a $100 bill on the desk saying he wants to inspect the rooms upstairs in order to pick one to spend the night.
As soon as the man walks upstairs, the owner grabs the bill and runs next door to pay his debt to the butcher.
The butcher takes the $100 and runs down the street to retire his debt to the pig farmer.
The pig farmer takes the $100 and heads off to pay his bill at the feed store.
The guy at the Farmer's Co-op takes the $100 and runs to pay his debt to the lady of the evening, who has also been facing hard times and has had to offer her services on credit.
She, in a flash rushes to the motel and pays off her room bill with the motel owner.
The motel proprietor now places the $100 back on the counter so the rich traveler will not suspect anything.
At that moment the the traveler comes down the stairs, picks up the $100 bill, states that the rooms are not satisfactory, pockets the money & leaves.
NOW, no one produced anything...and no one earned anything...however the whole town is out of debt and is looking to the future with much optimism.
And that, ladies and gentlemen is precisely how our government is conducting business today!
Old Jan 13, 2010 | 04:33 PM
  #42
InTgr8r's Avatar
I thought I recognized the economics.
Old Jan 13, 2010 | 06:26 PM
  #43
RBull's Avatar
Rated M
It's been around for a while but still a goodie Swivel!! Thanks.
Old Jan 13, 2010 | 06:38 PM
  #44
Swivel's Avatar
Moderator
Well so have a lot of us here.
Old Jan 19, 2010 | 02:47 PM
  #45
InTgr8r's Avatar
....talking Chili (long)
I went to Home Depot recently while not being altogether sure that course of action was a wise one.. You see, the previous evening I had prepared and consumed a massive quantity of my patented 'you're definitely going to schite yourself' road-kill chili. Tasty stuff, although hot to the point of being painful, which comes with a written guarantee from me that if you eat it, the next day both of your butt cheeks WILL fall off.
Here's the thing. I had awakened that morning, and even after two cups of coffee (and all of you know what I mean) nothing happened.. No 'Watson's Movement. Despite the chilies swimming their way through my intestinal tract, I was unable to create the usual morning symphony referred to by my dear wife as 'thunder and lightning'.
Knowing that a time of reckoning HAD to come, yet not sure of just when, I bravely set off for Home Depot, my quest being paint and supplies to refinish the deck. Upon entering the store at first all seemed normal. I selected a cart and began pushing it about dropping items in for purchase. It wasn't until I was at the opposite end of the store from the toilets that the pain hit me.
Oh, don't look at me like you don't know what I'm talking about. I'm referring to that 'Uh Oh, Schite gotta go' pain that always seems to hit us at the wrong time. The thing is, this pain was different. The chilies from the night before were staging a revolt. In a mad rush for freedom they bullied their way through the small intestines, forcing their way into the large intestines, and before I could take one step in the direction of the toilets which would bring sweet relief, it happened. The chilies fired a warning shot.
There I stood, alone in the paint and stain section, suddenly enveloped in a toxic cloud the likes of which has never before been recorded. I was afraid to move for fear that more of this vile odor might escape me. Slowly, oh so slowly, the pressure seemed to leave the lower part of my body, and I began to move up the aisle and out of it, just as an orange aproned clerk turned the corner and asked if I needed any help.
I don't know what made me do it, but I stopped to see what his reaction would be to the toxic non-visible fog that refused to dissipate.. Have you ever been torn in two different directions emotionally? Here's what I mean, and I'm sure some of you at least will be able to relate. I could've warned that poor clerk, but didn't. I simply watched as he walked into an invisible, and apparently indestructible, wall of odor so terrible that all he could do before gathering his senses and running, was to stand there blinking and waving his arms about his head as though trying to ward off angry bees. This, of course, made me feel terrible, but then made me laugh. ......BIG mistake!!!!!
Here's the thing. When you laugh, it's hard to keep things 'clamped down', if you know what I mean. With each new guffaw an explosive issue burst forth from my nether region. Some were so loud and echoing that I was later told a few folks in other aisles had ducked, fearing that someone was robbing the store and firing off a shotgun. Suddenly things were no longer funny. 'It' was coming, and I raced off through the store towards the toilet, laying down a cloud the whole way, praying that I'd make it before the grand explosion took place.
Luck was on my side. Just in the nick of time I got to the john, began the inevitable 'Oh my God', floating above the toilet seat because my azz is burning SO BAD, purging. One poor fellow walked in while I was in the middle of what is the true meaning of 'Shock and Awe'... He made a gagging sound, and disgustedly said, 'Son-of-a-bitch, did it smell that bad when you ate it?', then quickly left.
Once finished and I left the restroom, reacquired my partially filled cart intending to carry on with my shopping when a store employee approached me and said, 'Sir, you might want to step outside for a few minutes. It appears some prankster set off a stink bomb in the store. The manager is going to run the vent fans on high for a minute or two which ought to take care of the problem.'
My smirking of course set me off again, causing residual gases to escape me. The employee took one sniff, jumped back pulling his apron up to cover his nose and, pointing at me in an accusing manner shouted, 'IT'S YOU!', then ran off returning moments later with the manager. I was unceremoniously escorted from the premises and asked none too kindly not to return.
Home again without my supplies, I realized that there was nothing to eat but leftover chili, so I consumed two more bowls. The next day I went to shop at Lowe's. I can't say anymore about that because we are in court over the whole matter. Bastards claim they're going to have to repaint the store.
