Canada Serving Canada.
Where to Replace Bushings in Edmonton
Old Apr 15, 2010 | 06:36 PM
AidanP's Avatar
Hey guys, I've been trying to diagnose a rattle/knock coming from my rear suspension for a while now. I'm pretty confident that its being caused by the bushings at the bottom of the back struts. Mine are pretty mangled and need to be swapped out. I'm going to pick up a set of aftermarket bushings, but I was wondering if anyone could suggest a good place to get them done. I'm hoping I won't have to spend an arm and a leg on these things. Thanks for your input.
Old Apr 18, 2010 | 07:01 PM
AidanP's Avatar
No one has any suggestions?
Old Apr 19, 2010 | 11:24 AM
Swivel's Avatar
Moderator
Wish I could help you, Aidan, but I don't know the Edmonton shops at all. Bump for bushings.
Old Apr 19, 2010 | 09:41 PM
red35's Avatar
I am not sure either. I am getting some diff bushings done at Lightspeed innovations in red deer.
Old Apr 19, 2010 | 11:10 PM
AidanP's Avatar
I wish Lightspeed was closer. I dropped by Project Omega today. I talked to Rob the owner. He seems like a good guy and definitely knows his imports. He said it shouldn't be more than an hour and half to replace both bushings. Have any Northern Alberta guys had any luck with Omega? I know Sean got his stretch tires mounted there and didn't have any complaints. When my WORKS arrive, I'll probably do the same.
Old Apr 20, 2010 | 12:17 AM
Karma's Avatar
I got them mounted at fast tech. Either way my buddy Jon shoots for Project Omega- they know their stuff thats for sure.
Old Apr 20, 2010 | 12:26 AM
AidanP's Avatar
Well now I feel like an idiot. I would have sworn that you said Speedworks.
Old Apr 20, 2010 | 03:18 AM
Sylvan lake V35's Avatar
I met Rob before he seems like a good guy and have seen some of his work....it is ok. It is the only shop in Edmonton I would take my car to.
Old Apr 20, 2010 | 10:22 AM
AidanP's Avatar
He seemed to know a lot of you guys. He mentioned Sasha's mid mount build and the "silver" JWT TT from Sylvan Lake. He also offered to help me install my front, sides and rear (pre-fitted and painted) for a small charge on the side. Would you recommend doing that with him, or are there better options out there?
rezendvous420
May 31, 2020 01:26 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
si_driver
Aug 11, 2015 07:08 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
