Canada Serving Canada.
Stainless steel Brake lines...worth it?
Old May 3, 2010 | 09:28 PM
GD-Up's Avatar
Hey all,
With my new found brake paranoia, i was wondering if anyone had first hand experience with steel braided brake lines. Are they worth it? (on a street vehicle.)
Thanks!
Old May 3, 2010 | 09:46 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If you're still on the origunal 'os lines they should be replaced anyway, might as well get the good stuff.
They aren't a day/night type of upgrade but they do give better pedal feel/modulation.
Under hard braking there is less line flex, therefore more force at the pads.
Also, make sure you get the type that have the coating over the braid. (most of them do now)
Old May 4, 2010 | 09:49 AM
gcoupe_toronto's Avatar
why is that? I thought the same but my mechanic told me there is no point the lines for my brembo's should be fine
Old May 4, 2010 | 10:08 AM
InTgr8r's Avatar
They do last a long time, but after 7 (in your case) years of flexing under pressure.
JMO, but I would be thinking of replacement as preventive maintenance.
(nothing conclusive to say they must be done)
Old May 4, 2010 | 11:04 AM
Locksmith's Avatar
Its not necessary just yet but like Intgr8r said its really your personal choice, if I were you I'd change it the lines the next time you do the brake pads/rotors.
Old May 4, 2010 | 11:18 AM
RBull's Avatar
Rated M
I replaced them on my Brembos. It's a relatively cheap upgrade and worth doing if you want the best or spend time at the track.
Old May 4, 2010 | 12:53 PM
GD-Up's Avatar
Thanks for the feedback folks. I guess peace of mind is worth the extra $$$...and better pedal feel can't hurt either.
Old May 4, 2010 | 12:56 PM
dofu's Avatar
20 Year Member
IMO, yes they are worth the money. A Stillen brake master cylinder stiffener will help your brakes respond better too! Probably a bit better than the brake lines, although IMO the brake lines gets rid of a weaker link.
Old May 4, 2010 | 04:58 PM
L23Tan's Avatar
With the Stillen Brake Stiffener installed, you can't install a Strut Bar, correct?
Old May 4, 2010 | 08:11 PM
dofu's Avatar
20 Year Member
I guess that depends on the strut bar. But most of these strut bars don't do as much for chassis reinforcement as the brake master cylinder stiffener does for the brakes anyways. Ideally, you want a 3 point strut brace that reinforces the firewall, either or strut bars with fender braces. Anything else is mostly looks.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
