Canada Serving Canada.
Front grille paint..just not staying on
Old Mar 18, 2011 | 11:58 AM
railer's Avatar
Folks need some suggestions..
I dont seem to be having any luck with getting the black paint on the grille to stay on for more than 2 months or so.
granted i only paid like 50 bux or so to my mechanic to have to blacked out (thought that would suffice, but it doesnt seem to working out that well).
I'm starting to get tired of having the paint flaking and the stone chips are not helping either.
its starting to look real ugly now.
I have googled and read a few guides on painting the grille and seem to grasp what is needed, but i dont have the tools/supplies or the place to attempt this DIY.
so if any1 on here as got their's painted and seem to have got good results, could you please point me in that direction and how much would you say is a fair price for having this properly done (like the preping with sand paper, de-greasing, applying primer, adding adhesive components and 2-3 coats of the black paint).
Thanks
Old Mar 18, 2011 | 12:55 PM
STCLAIRWEST's Avatar
GeeRider did mine and is still in perfect condition, pm him.
Old Mar 18, 2011 | 01:55 PM
redpearl99's Avatar
poly is much more difficult to paint, flaking occurs much more often
Old Mar 18, 2011 | 03:41 PM
GeeRider's Avatar
do you have a stock grill of polly like redpearl mentioned, couldnt tel from your post, if its poly flex additive is a necessity, if its stock, just good sanding, primer, paint , clear.
Old Mar 18, 2011 | 04:14 PM
railer's Avatar
Its the stock chrome grille.
I think the issue mite lie with the fact that i wanted a flat/matte look, and my mechanic didnt put clear coat on, as it would make it glossy (thats wht he said..lol).
Old Mar 18, 2011 | 07:13 PM
GeeRider's Avatar
^pmed you, almost all the grilles ive done are in matte black, the clear does give it abit of a shine but its really subtle. Makes it satinish, but its can be done without the clear.
the clear just gives you extra protection against stonechips, wont make it stop peeling, its peeling cause you guy didnt sand and prep the surface, so the paint didnt adhere properly
Old Mar 18, 2011 | 10:08 PM
Infiniti Chica's Avatar
I did mine about 18 months ago and have had only 1 small chip about the size of a pencil eraser. Prepping was the time consumer. I did it right on the car, w/o detaching the grill. I used oversized trashbags with blue painters tape and covered the hood, lites, and sides pretty well. That took about 15 minutes.
Then the grille was wet sanded very carefully with fine grit paper. It took about 20 minutes to sand thoroughly, then it was washed and dried 2X. It sat in the sun for about an hour and then 2 coats of primer were put on. I waited about 30 minutes between each coat. Finally I used Duplicolor, glossy black, and put 3 coats with 30 minutes between coats. Finished it with clearcoat (2 coats).
It sat in the garage overnite to make sure it dried thoroughly before driving it. I didn't go the matte route, it made the grill stand out too much and had a slight greyish tint. But that's just a preference thing.
Good luck. The entire process took about 4 hours, and 85% of that was really only in waiting for things to dry. So I read between coats.
By the way, I did it in my yard on the lawn, so space wasn't an issue. My best advice is to take your time and make sure there isn't any wind blowing.
Old Mar 18, 2011 | 10:45 PM
rpm&my_G35's Avatar
I did this (http://gshack.org/?p=196) and it still looks as good as day one. It held up through the harsh winter salt and grime. Call it what you will but it looks good far away and close up. I can take it off if/when I get tired of it.
https://g35driver.com/forums/canada/...new-smile.html
Old Mar 19, 2011 | 03:05 PM
4DGS's Avatar
Bhav, you don't need to use a flex agent in any kind of poly parts except for a bumper where it will obviously flex often. With the grille it needs to be prepped properly and then an adhesion promoter needs to be applied before the primer.
Old Mar 19, 2011 | 03:15 PM
GeeRider's Avatar
yea its a stock grill anyways, just needs to b prepped
Old Mar 20, 2011 | 11:46 AM
jdm_dudebro's Avatar
Try doing it yourself. I drive alot on hwy and my grill is still good. I used... Dare I say... Plastidip. Did it myself with minimal prep. No sanding, and looks great! It's also a textured black. Did it for 12 bucks and in a quarter of the time that these guys took. Good luck n take the time to remove it from the car. It doesnt take much.
Old Mar 20, 2011 | 11:48 AM
I will help u do yours if you want my assistance. Free is better than paying 50 bucks for a few mins work.
Old Mar 21, 2011 | 10:29 PM
L23Tan's Avatar
GeeRider did my front grille in a matte black.
So far, no nicks, no scratches, no peels!
Good job Bhav!!!
Old Mar 23, 2011 | 12:18 AM
railer's Avatar
Yeah ill be doing the same pretty soon.
My previous 2 attempts havent really brought out any good results..lol
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
rymian
Sep 9, 2015 08:03 PM
realtalk21
Jul 20, 2015 09:07 AM
