Canada Serving Canada.
Suggestion: LED conversion service
Old Mar 28, 2011 | 10:14 PM
  #31
g35man04's Avatar
CLUB MODERATOR
Originally Posted by nissin67
^ What about 05+.. do you have to remove the orange paint or it is just leds?
Yes you still require sanding if I remember correctly however no hot spots. Mine are pretty good since he switched to wide angle led in my cluster....
Old Mar 28, 2011 | 10:22 PM
  #32
pl_G35's Avatar
You can't sand the 05+ because the orange is on the front, just swap out the LEDs. With red LEDs you can't even tell that there is an orange film on it.
Old Mar 28, 2011 | 10:29 PM
  #33
nissin67's Avatar
so you can't do white leds cuz it will only show up at orange for 05+?
Old Mar 28, 2011 | 10:32 PM
  #34
pl_G35's Avatar
For now you can't do white. There is a company I read somewhere that is prototyping with a custom faceplate and once that goes on sale you will be able to do white.
Old Mar 28, 2011 | 10:33 PM
  #35
pl_G35's Avatar
You can do the rings white since its a circle and very easy to sand off but the rest is impossible.
Old Mar 28, 2011 | 10:38 PM
  #36
CandlestickPark's Avatar
ill Sedan
LEDmod.com, this will be going in my car soon.
Old Mar 28, 2011 | 10:46 PM
  #37
pl_G35's Avatar
^ that's the company. How is it around the odometer since the stock one is indented in that spot and goes lower and this on is flat?
Old Mar 28, 2011 | 10:49 PM
  #38
ill Sedan
^Supposed to fit just like OEM, it just doesn't have the indented spot in the middle. I'll post up pics of everything once its done.
Old Mar 28, 2011 | 10:54 PM
  #39
nissin67's Avatar
^ so you basically change all the leds in the cluster - and then put this faceplate? or this comes with led in the back?
any pic of the backside?
Old Mar 28, 2011 | 10:57 PM
  #40
ill Sedan
Still need to change the leds in the cluster from what I understand. Because this one doesn't have the amber film on it the color will shine through perfectly even. This is the only pic I've seen of the gauge cluster.
Old Apr 21, 2012 | 05:48 PM
  #41
gary c's Avatar
Hi Marcus....=oD
Marcus, would have sent you a PM but your file is full. I'd like to convert my dash to the same color blue LEDs my Autometer cobalt gauges have. Did you get your dash completed and by whom? What are we looking at cost wise $300 +/-?
Gary
Old Mar 7, 2013 | 03:19 PM
  #42
adrst2.3's Avatar
back from the dead thread!
Is anyone still interested in this i do conversion for all type of cars
heres a link to the Lincoln LS forum.i did a conversion for a member there
http://www.lincolnvscadillac.com/showthread.php?t=88080
theres before and after pics of the conversion
heres a couple of links to the ford focus forum i do led interior conversions and custom mods for as well as hydro dipping
http://www.focusfanatics.com/forum/s...d.php?t=309414
http://www.focusfanatics.com/forum/s...d.php?t=307657
I offer other led mods as well as carbon fiber hydrodipping.
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Gabe83714
Oct 6, 2015 06:40 AM
