Canada Serving Canada.
Gear gridding noise
Old Oct 27, 2005 | 06:37 AM
jessica's Avatar
Question Gear gridding noise
Hi Guys ,
I have 05 AM sedan with 4000km on it . I have noticed there is a gear gridding noise when the car shifts from first to the next gear. It only happened every time the car is starts with cold engin . Is it something I should be worry about ? Thankx for the help
Old Oct 27, 2005 | 06:57 AM
akrus's Avatar
Can you describe the sound? Is affecting the shifts (slow??)? How long does the noise last? A couple of seconds/split second? Does it happen if you use the manual shift?
I really doubt it's the transmission, but it's going to be tough to diagnose without specifics.
Albert
Old Oct 27, 2005 | 07:08 AM
jessica's Avatar
Hi akrus ,
I have 05 AT . the noise only last few seconds as the car shift from first gear to the next . This only happened while starts the car every morning . This gridding sound reminds me the what happen when you miss a shift with MT car . I hope this helps .
Old Oct 27, 2005 | 07:19 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Does it only happen as you start & then it's OK after that?
If so, what you are hearing is the ABS system initializing.
It's normal for the system to do this.
Old Oct 27, 2005 | 07:30 AM
akrus's Avatar
Originally Posted by jessica
Hi akrus ,
That's nasty, if that's the sound you're hearing, I would definitely make an appointment with your dealer. Is it that loud? Try driving it in manual mode, the next time you think it might happen. Hold off on shifting to second until out of the 'expected' window that this normally occurs.
Another suggestion would be to meet up with someone that has a G and compare. I'm in Kitchener, but in Toronto on Sunday so if I can be of any help, just let me know.
Intgr8r, I think I know the sound you're referring to. I have noticed what sounds like a slight 'klunk' (bad word for it), when pulling away after the car has sat for awhile. It seems to be more prevalent if I reverse the car and leave the wheel turned slightly when parking. When pulling out, after letting the car sit for a number of hours, I occasionally hear this sound. It reminds me of a bad CV joint type of sound, but it's very momentary and never occurs while driving. I'll have to pay more attention to it, but I never considered the ABS normallizing as a possibility.
Albert
Old Oct 27, 2005 | 07:41 AM
InTgr8r's Avatar
On mine it's a chattering/ratcheting sound
Old Oct 27, 2005 | 07:55 AM
akrus's Avatar
I'll give it a listen at noon, but that sounds similar.
Albert
Old Oct 28, 2005 | 01:32 AM
QRAFTWERKZ's Avatar
Best is to leave it a the dealer for a COLD start check, as the noise only happens when the car is cold - Sorry wish I could recommend a dealer for you.
But try this for starters....wait a few moments before actually accelerating let the trans fluid circulate. And the other thing is where exactly is the noise the loudest left side, right side, rear, middle?
Good luck
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
